01-07-2001, 12:10 PM
Does anyone know of the guy who can build the TBI injection kits? Isaw his post here somewhere but cannot locate him. Also, is anyone familiar with his product and if so, is it good? Thanks
Lippy
'86 GW
Pure stock
01-07-2001, 12:34 PM
Off hand, I seem to recall a few people who make 'boxes' and harnesses for GM TBI's to be bolted onto just about anything... Once you got those two pieces, all you'd need would be a carb adapter (1/2" plate aluminum/steel/whatever you have lying around) some slight modifications to the fuel delivery system (remove mechanical pump, install electric + regulator) And Le Voila!
Have a look through the hotrod mag's, and maybe advance adapters website.
Andy
79 Wagoneer LTD "Shake N Bake"
Calgary Alberta Canada (Eh!)
http://albums.photopoint.com/j/Album...185&Auth=false <=- closest thing to a website I've got
01-07-2001, 12:41 PM
Search for TPIGuy on the forum and get his email that way.
JeepFreak
01-07-2001, 12:48 PM
Ok I found it for you. His name is TPIGUY and he sells FI systems. Here is his mail... weg1192@aol.com . I'm sure he can give you all the specifics on his kit.
JeepFreak
[This message has been edited by JeepFreak (edited January 07, 2001).]
01-07-2001, 01:23 PM
Third Member
Guys, I've edited this post to remove the link to TPIGuy's page. His email is weg1192@aol.com, and he has expressed a preference to exchange information that way.
Sorry about the mixup, TPIGuy.
J ust
E mpty
E very
P ocket
[This message has been edited by Ralph (edited January 09, 2001).]
01-07-2001, 04:26 PM
Since both my 79 and 86 use f*rd carb and ignition systems I have been wandering about adapting a f*rd 2bbl TBI system to one of them. The throttle body should bolt on to the manifold and the ignition should interface with the control module. It seems that this would be simpler than adapting a GM system in place of so many f*rd parts
01-08-2001, 12:48 AM
I ordered a holley motorcraft 2300 2bbl adapter for my holley projection 2bbl system. I assume that it will work to replace my 2150 with the holley TB which I think is just a modified GM 2bbl TB.
I'll let you know if a week or two if this is the case when I try to install it.
01-08-2001, 04:37 AM
The Holley is a custom unit, looks nothing like the GM TBI. I suspect it's a Holley 2bbl carb with the guts stripped out and a new casting made.
01-08-2001, 09:39 AM
Bummer, thanks for the info.
01-08-2001, 11:25 AM
Hey Lippy,
Its me its me, its Earnest T. My websites are found at:
http://members.aol.com/customefis
TPIGUY
01-08-2001, 11:32 AM
By the way, getting a GM TBI system to work on an AMC 360 is more than just finding the parts in a junkyard and installing them. The main issue is getting a chip retuned to run the gas guzzling 360. The GM system, although good at selftuning, can't add enough fuel in stock form to run an AMC 360 well. It took me over a month to retune the chip to run my AMC 360 well. That time also included the spark timing.
01-08-2001, 11:41 AM
Fooska,
You may be able to use Ford parts, but my understanding is that Fords chips are harder to reprogram, not impossible just harder. I have no trouble interfacing to the Ford Duraspark distributor on my GM TBI kits.
01-08-2001, 12:25 PM
TPIGUY:
I wonder how your chips differ from the one included with the Howell system?
Gregorio
Austin, TX
'87 GW "Big Grin"
01-08-2001, 12:31 PM
I understand that this TBI system will work on both 2v and 4v manifolds. What is the difference between the 2 systems?? ie. performance, bottom end, milage, etc..
Also, is there some kind of adapter for one or the other that would keep you from swapping the system from 2v to 4v manifold at a later date??
DON
1988 GW mostly stock, <---Wifey's truck (won't let me "fix it up")
1971 J-4000,Rhino Grille(to be installed)
360 CID 8.5/1 ratio 2v, 245 HP, 365 ft/lb
T-18A, Dana 20, PTO, DANA 44 (Front/Rear)
Soon to be torn down for Resto
71 Gladiator Pics
78 GW (parts truck)
360 4v Th400
Dana 44 F/R
http://www.j-trucks.freeservers.com/
78 Wagoneer Pics
01-09-2001, 12:52 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by Ralph:
That's the correct email address. Here's his web page:
http://members.aol.com/customefis/360install.html
<HR></BLOCKQUOTE>
Hey wait a minute. This link worked last night. What happened?
Guy
01-09-2001, 01:31 PM
Guy,
I saw that Ralph had posted my AMC 360 installation website on this forum. Since that site contains detailed information that I consider crucial to my kits, I would rather that site not be public information. I only provide that link to paid customers now. I will answer any specific questions by Email.
Gregario, I have a Howell 4bbl TBI chip in my possession. It came out of an ECM normally used on multiport TPI EFI. My research indicates that using a TPI ECM on a TBI setup causes some cylinders to run lean due to the injector firing frequency difference between TBI and TPI ECMs. But, when I have the time, I plan to test the TPI ECM on my Jeep with a TBI setup. Then I'll compare the Howell chip with my tuning efforts. Right now, I have my hands full filling orders for others.
Gladi8r, What I do is build two adpater plates. One is necessitated by poorly located holes on the 2 to 4 bbl adapter I buy. The other provides two TBI holes on top of any standard Holley square bore 4bbl manifold. In essence, its much easier to install a TBI on a 4 bbl manifold than a 2 bbl since what I do is first convert the 2 bbl to accept a 4 bbl carb. To answer your question, you would already have everything you need to mount a TBI to a 4 bbl manifold if you had one of my 2 bbl kits first. On the performance question, I had a generally smoother running engine, especialy at hiway speeds. It pulled a lot stronger at 80 MPH than it did with a 2 bbl carb. My mileage went from 12 to 15 MPG at 70 MPH.
01-09-2001, 02:13 PM
Third Member
I noted another kind of throttle body injection in the latest Jegs catalog, by Barry Grant, called VFI Injection. Anyone have experience with this yet?
http://www.bgfuel.com/bgfuel/fuelinjection.htm
J ust
E mpty
E very
P ocket
01-11-2001, 04:14 AM
I am surprised to hear that a stock GM chip will not function in a GM TBI System transferred to a jeep. It dang sure did on my recent 5000 mile trip from Austin, Tx to Portland, Or and back. Not a hickey.
01-11-2001, 10:19 AM
[quote]Originally posted by Aragorn:
I am surprised to hear that a stock GM chip will not function in a GM TBI System transferred to a jeep. It dang sure did on my recent 5000 mile trip from Austin, Tx to Portland, Or and back. Not a hickey.[quote]
Aragorn,
Please email me at <rebelyell54@yahoo.com>.
Thanks.
Guy
Thread Tools |
Display Modes |
