This is only one question of a couple I have...
I bought the bjs exhaust kit, went to install it, and sheared a few bolts off in the manifold off the y-pipe. So while I decide if I want to pull those out, or just toss another used set of manifolds on, I had a few other questions...
to weld, or to clamp exhaust pipe? the previous owner had everything welded. Who ever did the welding did a shoddy job, because the welds ended up being very holey (and not just on sundays). So one would think that by clamping everything, you don't have to worry about the weld joint being the weakest link in the exhaust system.
Next question- to air pump or not to air pump... reading a few threads on here, it would seem if you don't need it, don't use it. But since I got the kit with the cat with an air tube, I should use the air pump, to avoid early deterioration of the cat.
But running the air pump "technically" can affect gas mileage, because it's an add'l accessory being run, correct?
the easy solution would be just to convert everything to clamp, run the air pump till it or the exhaust dies, and just redo it all, with a 3way cat and no air pump...
or is there a simpler solution to something I'm probably making more complicated than it already is?
Either way, now I gotta find a new ypipe, for the exhaust kit I have taking up space on my harley and the garage floor...
