I was researching this engine as my dad has one in his CH Chrysler. Its bolted to a TF727 trans. How hard would this be to drop into an FSJ considering its got the TF in place? Check out the torque numbers.
My Dads has about 70000 original kms on it. The body is about to fall off it but the donk is lively and smooth.
360 V8:
Run down on the Engine back ground:
The New 360 V8
Both the sedan and Hardtop versions could be ordered with a choice of 265 Hemi, through to the newly introduced ?360? V8, this stonking 5.9 litre unit being rated at 190kW (255 bhp) and was manufactured at Chrysler?s Lonsdale (South Australia) facility. The 360 was a further development of the Fireball 318, the increase in power and size gained by using a larger bore and stroke, while the fitment of a two-barrel carburettor ensured the engine offered better performance, and worse economy if pushed hard. Whichever engine was chosen, Chrysler then mated it to an imported ?TorqueFlite? three speed automatic transmission, the locally manufactured version deemed less smooth.
360 V8:
- Capacity: 360 cubic inches (5.9 litres)
- Type: Conventional, watercooled four stroke, reciprocating piston type with 8 cylinders
- Configuration: Front mounted, longitudinal, OHV, 90° Vee, "wedge" head
- Head: Pushrod and rocker actuated ohv with two valves per cylinder
- Fuel System: Holley two barrel downdraft type carburettor
- Bore and Stroke: 4.00 x 3.58 inches (101.6 x 90.932 mm)
- Power: 255 bhp (190 kW) at 4400 rpm
- Torque: 360 lb-ft (488 Nm) at 2400 rpm
- Compression Ratio: 9.2:1
- Valve Timing
- Intake
- opens: 16° BTC
- closes: 56° ABC
- duration: 252°
- Exhaust
- opens: 60° BBC
- closes: 16° ATC
- duration: 256°
- Intake
- Firing Order: 1-8-4-3-6-5-7-2
- Radiator Capacity: 26 pints
- Oil Pan
- Without filter: 6.6 pints
- With filter: 8.3 pints
The New 360 V8
