I have a popping in the front end that can be heard and felt thru the floor when I turn hard right or left, only seems to do it on hard surfaces, I couldn't find anything loose except I have play in the driveshaft u-joints on both sides. The aren't locked in so they shouldn't be turning but I'm not sure that would rule them out, anyway they need changed. Are those a standard size u-joint like the drive shafts or different? Its an 82 w/360/727/208, D44 front/AMC 20 rear.
Also the steering shaft has a small u-joint on it up clost to the firewall, I do have play in that also, is it possible to repair / replace that one without replacing the whole steering shaft?
Thanks guys
Thanks guys
