My new '91 GW is great and for about a month I've been ignoring the fact that the window in the tailgate won't work. Yesterday I decided that I might as well tear into it so I'll be ready when I need to use it. Before I started I read the articles in the tech archives by Michael Baxter ( FSJ Guru) and the others. I got the tailgate apart and determined that the motor works fine by using the direct connection technique suggested in one of articles. BTW, the strips on the floor of the cargo area of your wag make a great ground for electrical connections...near disaster, but that's another story. After tearing the tailgate apart I determined that the PO had disconected the dash switch connector, so I plugged it back into place. Still no response from the dash switch, but by "jiggling" the key in the tailgate switch I could raise and lower the window. Great, I was at least partly back in business. I put everything back together, checked to make sure it still worked with the jiggling technique and went to bed happy that I had conquered the tailgate beast. The next morning the battery in the wag was dead and I then knew why the dash switch had been unplugged. Back to the drawing board. I have a Haynes repair manual and the wiring diagram in it shows the tailgate wiring in the '89 - '91 wags to be different from the earlier years which explains why some of the info in the tech section didn't seem to apply. In the '89 -'91 models there appears to be a relay in the tailgate and the rear switch appears to be grounded separately, unlike the earlier models which have no relay and no separate ground for the rear switch.
Everything is back together, but now nothing is working except the defroster which works even though the plug on the dash switch for the tailgate window is unplugged. Does anybody have any suggestions where to look for the problem?
