I finally received the radiator. I installed it and let the engine warm up. It runs all on it's own now and doesn't die when I press the accelerator. I took the video from outside the garage because the smoke coming from this thing is horrendous... I imagine a combination of 5 year old fuel, Marvel Mystery Oil, and some Sea Foam fogger sum up most of the contributors. There is quite a bit of smoke coming from either side of the engine, too. I think there are some spilled fluids on there. I wish I could have done this all outside but it is not very practical at the moment. I had a big fire extinguisher ready to go, just in case.
'80 Wagoneer Limited (AMC 360)
Nice job!
Hey, I'm feeling a lot better going on 7 weeks after my surgery so let me know if you want to get together at some point and shoot the .
I'm hoping to get in the garage tomorrow and restart on my own build.--Rob--
My build thread:
https://forums.ifsja.org/forum/tire-...er-restoration
My Howell TBI Install How-To:
https://forums.ifsja.org/forum/tire-...rb-e-o-d-452-2
Heck yeah!!! Way to WIN!!!!! So awesome!!!!Chuck McTruck 71 J4000
(Chuck McTruck Build Thread)
00 Baby Cherokee
IT MOVES!!!
I am so excited! I bled the brake lines again (properly) and they work! I backed out of the garage and around the block I went in this boat. I don't know if the front end felt soooo loose because of the missing frame section or if it is from really low tire pressure or maybe bad steering components. It is the loosest front end I have ever felt, that is for sure.
Totally agree with Fleet Fox. Don't just throw parts at it and don't go nuts fixing tons of things. just fix the big things here and there and enjoy it. Steering should be pretty easy.Chuck McTruck 71 J4000
00 Baby Cherokee
I felt like I was riding in the truck with you,....
and we got loose on the straight-away,.....wooaaahhhhh.
driveway only for now.........
get that frame/steering fixed.
dave in NCSOLSAKS - dave
Originally posted by MysticRobNice job!
Hey, I'm feeling a lot better going on 7 weeks after my surgery so let me know if you want to get together at some point and shoot the...
Originally posted by rang-a-stangHeck yeah!!! Way to WIN!!!!! So awesome!!!!
Originally posted by FleetFoxNice going! Just take everything 1 piece at a time. From the driving video, it appears assessing the front steering components might be next on your list!
Pysched for you,
Fleet Fox
dave in NC
Big Day!
I decided to fire it up to check the coolant temp while warming up and see how it would idle. I felt a little inspired so I drove around the block (5-10MPH) about five times, with a big fire extinguisher and a tow strap riding shot-gun. I stalled two or three times before figuring out where to set the flange on the carb (what is the flange called? the choke?).
It was running consistently but did not like when I pressed the accelerator and would bog down if I did so. It would drive well without giving any throttle, so I decided to take it to a gas station three blocks away.
This allowed me to finally dilute the 5 year old fuel which plagued it's belly. I don't know what was living in the fuel filler tube, but there must have been something because I had to trickle fuel until it was washed down enough for it to flow (not ideal haha). I topped it off, hit a couple of speed bumps, and all of a sudden it ran really well!
I kept it slow and decided to go to another gas station three more blocks away to get some air in the tires. I drove it with a bit more confidence and noticed a pretty good improvement in steadiness with appropriately filled tires.
My last adventure before heading to work was going to a car wash about six blocks away. I took lightly traffic'ed side streets just incase I experienced any problems. I made it all the way there with no issues, good coolant temp, and good oil pressure. I hosed down all the dried up brush which found its way into every nook and cranny on the Jeep and blasted most of the animal nests out of the engine bay as well as cleaned up a lot of the grime coating the steering components.
I am feeling pretty good about the progress on it so far. Feeling it drive and run autonomously was really encouraging.
Above are some photos of today's adventures!
I agree! I get all excited when I see updates here! What a HUGE difference in your engine bay! That flange is the choke. It should be just wide open when the engine is operating temp and fully closed when the engine is cold.
That bogging when you touch the gas probably has to do with either a carb rebuild or your timing signal to your distributor. Once you get your steering all sorted out, those are next. Both are easy and cheap but time consuming.Chuck McTruck 71 J4000
00 Baby Cherokee
cool
you drove it even more !..... dang !
I admire the fact you are not afraid to work on it
I love it when any vehicle is brought back to life
when most others would never try...
looking good.
this wagoneer found a good home.
Originally posted by 78 WIDETRACThis is a cool build thread, You have made some real good progress in a short period. The pics are cool too. Keep us updated.
Originally posted by rang-a-stangI agree! I get all excited when I see updates here! What a HUGE difference in your engine bay! That flange is the choke. It should be just wide open when the engine is operating temp and fully closed when the engine is cold.
looking good.
dave in NC
Update
With the use of some valuable knowledge from Rang, the Wagoneer now starts and runs really well! I was operating the choke in the opposite way as it is intended (open when cold & closed while hot)... *Rookie mistake*
The vehicle handles much better with fully inflated tires and no longer feels like a tin can on ice. I synched up the exhaust pipe to eliminate a squeak when it would rub one of the rear shocks and really am enjoying some short trips around the neighborhood! I also changed the oil and learned something new about the crankcase breather (it's also the oil filler). I was very lost when I couldn't find an oil filler spot!
I am taking it out into nature today to photograph it and take a few drone shots before listing it for sale. I figure it functions well but needs a lot of restoring, which seems great for someone interested in an old project vehicle in running and driving condition. I feel I have done my part in keeping this old beauty alive and out of the grave, which we have lost so many old vehicles to...
I checked out the classifieds on here and realize there are some really affordable options on occasion and if I'm in need of a clean Wagoneer in the future, I'll know where to go!
