Long story short the vac at warm idle and vac can unhooked is around 14-15 and unsteady. i have all vacuum lines pluged even vac ball at back of engine that controls heat and a/c doors. Unhooked pwr booster no change. I have an Actron digital light that says my initial is around 32 deg idling at 700. Yea that is crazy. I hooked lead to #8 and 2, timing mark is closer to #1.Assuming light is malfunctioning. It starts and revs good. Used more than a can of carb clean. egr has not been hooked to vac. Original iron intake 2v is there any leaks possible within carb or intake. Thx
vac and timing
I was thinking if damper moved that much the rubber would be pretty distorted and would have vibration. Just changed carb gskt and i noticed 2 in of hg better but still shaky. Next morn had it warmed up and i lost that 2 in. It just likes bouncing around 14 or 15.88 GW hei E-fuel pump 360 rebuilt- rv cam
Originally posted by redwoody...I hooked lead to #8 and 2, timing mark is closer to #1.Assuming malfunctioning. It starts and revs good. Used more than a can of carb clean. egr has not been hooked to vac. Original iron intake 2v is there any leaks possible within carb or intake...--Rob--
My build thread:
https://forums.ifsja.org/forum/tire-...er-restoration
My Howell TBI Install How-To:
https://forums.ifsja.org/forum/tire-...rb-e-o-d-452-2
I have 2 harmonic dampeners one new one old.The old one is 45 degrees off still looks good,runs great just off a bit The new one is 180 off runs funny though. Just sayingOwner of Jakes FSJ Junkyard 91 Jeep Cherokee /2006 3500 Dodge AKA Babe the big blue puller
Hire the handicapped, they are fun watch!
replaced balancer w/oreilly warranty. Its 48* off. Physically bring #1 tdc and balancer is on mark. I have a much bigger issue. Young guy made a left in front of me. I think its totalled. Had her for 19 yrs.88 GW hei E-fuel pump 360 rebuilt- rv cam
I have seen vacuum leaks bounce the vacuum gauge needle, but I have also seen this when the aluminum rocker bridges are badly worn.Flint
