Old 08-05-2020, 07:48 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Question FULL BRAKE SYSTEM BLEED HELP NEEDED
I have just finished replacing everything from the master cylinder to the calipers and now have to bleed a bone dry brake system. I've done the usual bleeding of the brakes before, and once I did a bench bleed of a master cylinder using the syringe type bleeder tool. What is the best way to go about this?
I would love to be able to afford one of those Mity-vac electric pressure units, but the budget says No! Maybe a cheap hand pump version?
Originally Posted by will e
Old 08-05-2020, 07:51 PM
Mikel's Avatar
Mikel Mikel is offline
Bleed the master cylinder first and then work your way downstream.
I rigged a plate and a piece of rubber to feed compressed air into the master cylinder. It makes one-person bleeding very, very easy
1969 M715 6x6
1963 J300 Swivel frame
Old 08-05-2020, 08:00 PM
Tripwire's Avatar
Tripwire Tripwire is offline
i use tubes from outlet holes back to the reservoir, i dont know if you have to fab a prop valve holding thing......i use a mity vac to do the bleeding but a herlper also works, start with the longest line from the master
Abort? Retry? Ignore? >
Old 08-06-2020, 11:19 AM
Last time I did my whole system, I gravity bled it. Was stupid easy. put a vacuum line over each valve and drop that line into a cup/can/bottle, crack all of the valves open, top off your fluid, and make sure it does not go dry. Takes about 2 hours but it is THE EASIEST way to do it. And it works. I was skeptical when others recommended it to me but look it up. If you are in no hurry, that's the way to do it. You can work on something else and the system will bleed itself.
You can make one of those mity-vac systems for cheap with harbor freight stuff. I made one a while ago (you are welcome to borrow it if you pass through Camarillo again anytime soon) and i think i had about $15 in it? Again, google it and you will see a few How-Tos out there.
Old 08-06-2020, 04:09 PM
brielly's Avatar
brielly brielly is offline
I've had the best results with the one person bleeder sold in the auto parts store. It's basically, a cup, hose and fitting that inserts into your brake bleeder. Just pump the brakes and remove it when you no longer see air bubbles. Gravity bleeding would be my 2nd go to, just takes longer.
For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email rrielly@verizon.net
1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
Old 08-18-2020, 04:48 PM
Tigger4X's Avatar
THANKS FOR ALL THE INPUT GUYS! NEED MORE PLEASE!
I bought the syringe style tool to bleed the master cylinder and it worked great. I managed to keep the mess to a minimum and contained to shop rags. I went to go crack open the RR bleeder valve and then it went sideways. The axle is from a '79 J20 so it is a Dana60. A 3/8" is too small and a 10mm is too loose, risking rounding the buggers off. Is there some weird aftermarket valve that has some wild wrench size I am unaware of? For good measure I sprayed them both with PB Blaster hoping it will help when this gets figured out.
Old 08-19-2020, 08:33 AM
This worked great on mine:
https://www.harborfreight.com/brake-...der-92924.html
Old 08-19-2020, 07:59 PM
J20 project's Avatar
gravity bleed...I spent years attempting to use vac tools, etc...grav bleed.
J20
BP Drivetrain...........
775-537-7918
Old 08-20-2020, 10:27 AM
Tigger4X's Avatar
I ended up having to drop the axle to get a good grip on the valve with my vice grips, but they were going to inevitably round them off so I opted to smack a 3/8" deep socket on em and sure enough the came out nice n easy.
Originally Posted by MysticRob
Having had issues with a number of the Pittsburg tools I used a 20% coupon on the MityVac hand pump unit. To use the one you linked I'll need to borrow a compressor. IThe MV unit seemed like a good find and for a much better price than at my McParts store. Suffice to say it keeps solid pressure when suctioned to my thumb, but not so much on the valve. The 90
Brake System cma General FSJ Tech 3 06-04-2019 11:21 AM
J10 brake bleed blackj10 General FSJ Tech 2 03-13-2013 09:19 PM
brake bleed ? prop valve which button to push in AMX factor General FSJ Tech 7 06-09-2004 01:51 AM
probably not the last word on cooling.... brent General FSJ Tech 38 07-18-2003 08:29 AM
Am I too cool? waggin'ear General FSJ Tech 15 07-13-2003 05:22 PM
