Old 08-02-2020, 09:34 PM
puttyranger puttyranger is offline
Power Steering pump for a 71?
i am trying to replace the power steering pump from my 71 wagoneer with a 360. The thing is i cant find one. My question is can i use the pump from a 73, or what would be my best option.
Old 08-03-2020, 11:05 AM
7350life's Avatar
7350life 7350life is offline
It appears that you should be able to use the '73 PS pump on your '71.
Not that I'm suggesting that you should buy a heavy duty, $200+ PS pump, but this link shows that 1971-1979 pumps are interchangeable. https://www.bjsoffroad.com/PSC-Hi-Pe...ir_p_1919.html
1979 J10, 304 V8, 4-speed manual
Old 08-03-2020, 01:16 PM
The parts book shows a different pump for a '71 (4488077) and a '72 (3213992).
I would guess that it's the same as the pump for an AMC car with the 360, and the listing makers just don't have a clue about what's right for a Jeep. RockAuto shows several suppliers for a pump that fits a 1971 360 Ambassador, for instance. These engines were a commodity provided to Jeep for installation in their vehicles, and they would not have varied from the normal passenger car configuration.
RockAuto shows both the early style cylindrical reservoir with a long neck, and the later "canned ham" style reservoir. Which do you have now? Suggest you ask your local friendly parts store to order in a pump for a '71 AMC and compare to what you have. They should let you compare side-by-side - does not cost them anything but time.
I would absolutely not turn in my core until the new pump was installed and demonstrated working.
Old 08-05-2020, 02:24 AM
I'm not sure how to load pictures. It says my file is exceeded by the size of the image
Old 08-05-2020, 02:35 AM
Brynjminjones's Avatar
The best way to post pictures is to use an external hosting site. I've recently started using Flickr.
You just upload your picture to there, then copy and paste the sharing link into your post on here
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 08-05-2020, 03:44 PM
i think i did it
Old 08-05-2020, 03:50 PM
Old 08-06-2020, 04:08 AM
Maybe you could post a better picture - move back a little and let us see the entire pump and fluid reservoir.
Did you read my post above? Check the AMC car listings on RockAuto. The pump can be separated from the fluid reservoir. This does not look like a Saginaw pump to me. The listing on RockAuto shows both a Saginaw and an Eaton pump. Compare what you have to the pictures at RockAuto.
Old 08-06-2020, 05:58 AM
SC/397's Avatar
SC/397 SC/397 is offline
That is the Eaton Power Steering Pump. You probably can still buy a rebuild kit at NAPA for it. They were on all AMC cars 1966 up to 1971 or 72. Just order one for a '69 Javelin or any AMC car.
You could replace the whole unit with the later Saginaw Pump but you would need all of the brackets as well.
If you change it, I could use what is left of your smog pump brackets.
Old 08-06-2020, 09:37 PM
i will probably use rockauto....unless anyone has a different idea?
Old 08-07-2020, 11:41 AM
https://www.rockauto.com/en/catalog/american+motors,1971,ambassador,5.9l+360cid+v8,100 2283,steering,power+steering+pump,7380
https://www.rockauto.com/en/moreinfo...002283&jsn=349
Does not charge for a core, so it must be a new part. Any parts store could get this if you take these pages to them. Be sure to compare the parts side by side on the bench before you get the box and new part greasy/dirty. Check with the parts store that you can return the pump if it's not right. Or failing that, ask to compare the old and new part at their counter before you buy. (They should help you this way. If they don't because of "policy" or whatever, find another store.)
Battling Power Steering Pump Install/Removal xsloppyjoex General FSJ Tech 1 11-14-2014 09:26 PM
Hydro boost, Power Steering Pumps, and running larger tires-n-wheels. Texafornian General FSJ Tech 0 07-24-2014 01:09 PM
power steering pump & belt question roundss General FSJ Tech 3 02-09-2011 10:41 AM
Power steering pump Question Dan Stewart General FSJ Tech 3 04-20-2009 05:12 PM
GM Power Steering Pump Question ChuckWag General FSJ Tech 3 09-08-2003 03:46 AM
