I sold my last GW several months ago, and have been looking (without the wife knowing it) for another one since the guy drove off in it. I've found one with a 6 cylinder engine it. All I've ever had was the V8. Anybody got opinions on the 6 cylinder ones (1986 GW)? Thanks.
GW V8 vs. 6 Cyl Opinions
https://www.facebook.com/ClassicGrandWagoneers/
87 GW (White) - Incoming
89 GW (Black Cherry) - In Resto
85 GW (Gold) - In Resto
86 GW (Garnet) - In Resto
84 GW (Bronze) - In Resto
89 GW (Gray) - (Gone)
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
75 Cherokee S (Blue)(Gone)Tags: None
The 258 is a pretty darn good motor. Plenty of torque and decent power. I'm running one in my 83 J10 with 33" tires and it does okay.
That said, I don't think I'd want one with the 2.73 gears and an auto. I would think it would be a dog.Thomas Russell
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1970 Gladiator J3000 3407Z Camper Truck 350/T181968 Wagoneer Custom 327/TH400
Originally posted by drlockeUnless you are into competing with Camaro owners at the light, or intent on hauling a king-size trailer on the rig, the I6 is perfectly fine as an engine, and will serve you well as a reliable twirler.https://www.facebook.com/ClassicGrandWagoneers/
89 GW (Gray)(Gone)
87 GW (White)(Gone)
86 GW (Blue)(Gone)
88 GW (Gray)(Gone)
89 GW (Gold)(Gone)
89 GW (Gray)(Gone)
Originally posted by KaiserManThe 258 is a pretty darn good motor. Plenty of torque and decent power. I'm running one in my 83 J10 with 33" tires and it does okay.
I had an '81 Wagoneer Limited with a 258/727 and had 2.73 gears and yes it was very doggy.
Was not really able to pass trucks on the interstate or do well on small hills.
On flat open ground, it did okay.Bryan Smith
2017 Jeep Grand Cherokee Limited
- 75th Anniversary Edition - 1941 Trim Package - Recon Green
1986 Jeep J20
- Super clean rig from the AZ/CA state line
1982 Jeep J10
- Has become a Long Term Project.
1981 Jeep J20
- Commercial flat bed - Lost in a Divorce --gone
1987 Jeep J20 Pioneer
- Former Rick Bielec aka Ricbee plow rig. Major rust!! --gone
IFSJA Member #1933 Joined November 30, 2001
Originally posted by Jayrodoh...but if it works, I wouldn't touch it.Originally posted by LindelBest laid plans, yada yada yada...
If the 6 isn't quite enough with the horrible factory gearing in it it will be a whole lot cheaper to change out the gears than do an engine swap. If it were me i'd snatch it up and run it as is and change the gears if I needed to down the road. I bought an 82' with the 258 and T176 4 speed with 2.72:1 gears and it got up and went as well as the 89' with the 360 and auto. The auto will definatley rob some power though.Originally posted by Ristow
i bet it was Simon....
I have an '80 6-auto (727 & NP 228) with 3.31's, and it's just fine. Not a powerhouse by any stretch of your imagination, but certianly adequate. For years when my kids were growing up, I used it pretty regularly for pulling an 19 ft open bow runabout to the lake (60 miles one way).
It's only downfall for me has been that it's not a very good "dune runner", even in low range. The lack of torque in deep sand, even when in Low range, is such that you can get into sand deep enough to stall the convertor, with no way out other than to dig, or take a strap. (pretty minor issue IMHO...)
It's also survived two teenagers (survived is a relative term here, as the body is NOT what you could call very straight anymore ). It has 279K on the clock with the engine having never been opened up, other than to put a new timing chain in @ something like 248K, when my son let it run down to less than one qt of oil left in the pan...
Strange that it didn't hurt the crank or cam bearings, but am thankful for that, and the teen learned a few things about responsibility and the feel of shoe leather for a few weeks...
Tranny, T-case and axles also never been opened up... Been VERY impressed with it's reliability. Only major parts EVER replaced include;
Two fuel pumps, one water pump, one set of propshaft u-joints (frt & rr), one radiator, two sets of brake shoes, and three alternators (suspect the first vato-zone replacement alt. which only lasted about 2K, was a dud from the start).
Re being tempted to do a 360 swap, the 4.0L HO engine makes about as much power as the 2V 360 engine (185@4750 v. 175@4000, per Jeeptech). Tro me, this would be a much more appealing swap for a 258 Wagoneer than a 360. Of course, you'd need to take the Mopar MPI along with the engine, but I expect this combo would give you both better power and better fuel economy than the 258. Plus, it just drops in to the 258's place, whereas with the V8 you'd have to change the mounts fore and aft to make it work.Tim Reese
Originally posted by tgreeseRe being tempted to do a 360 swap, the 4.0L HO engine makes about as much power as the 2V 360 engine (185@4750 v. 175@4000, per Jeeptech). Tro me, this would be a much more appealing swap for a 258 Wagoneer than a 360. Of course, you'd need to take the Mopar MPI along with the engine, but I expect this combo would give you both better power and better fuel economy than the 258. Plus, it just drops in to the 258's place, whereas with the V8 you'd have to change the mounts fore and aft to make it work.88 Grand Wagoneer
99 Camaro z28
73 Honda st 90
79 F250
Yes, the 360 has more torque (285@2400 v. 220@4000).Tim Reese
My 2 cents are being thrown in!!!
Ok,
So I own,daily drive and wheel the snot out of (ask Tad!?!) my really ugly '83. Its a N/t Cherokee, 258, T-176-177 4 speed, NP208, and the AWSOME factory 272 gears!!!!LOL! I'm using a 4" rusty's kit to clear the BFG 33X10.50 MTs. I would'nt say its a complete dog.... maybe just a 3 legged one!! The only engine mods have been a webber carb, HEI ignition, and a straight pipe exhaust with some resonaters i nabbed from the scrap bin. It sounds like an Army 2 1/2 ton truck or some kind of cummins but it holds its own. The gears are the real limiting factor! 272's???? come ON!!! Who's the tard at jeep that though THAT was a good idea?? Still, should be cheaper to gear swap than change engines. I'd shoot for one with a good body/ little rust and a 6 cyl/4 speed. I'm still averageing between 16-19mpg... I never got that from my V8 powered waggy! Feel free to e-mail me if you'd like more in depth opinion! Cheers! Ted
Originally posted by addictedIf the 6 isn't quite enough with the horrible factory gearing in it it will be a whole lot cheaper to change out the gears than do an engine swap.
I thought and hard about regearing my 258 powered '81.
I would have needed to buy two new gear sets
Also, because I am not equipped for a gear swap, I would have paid someone $$$ for swap these gears out.
I could ahve found a rusted out Waggie to use a donor for less $$$ (easy to do here in the Rust Belt)
When I was planning what to do for my '81, for me, it would been much cheaper to buy a couple of axles that had the proper gearing and swap axles.
Yes, swapping axles and/or swapping engines are a lot more work than swapping gears.
To me, the axle or engine swap would be far simpler work to for me to complete than a gear swap.
When looking at a project like this, one must look at their skill sets, tools/equipment/facilities and budget.
I have time, skills and am equipped for a axle or engine swap.
I am not skilled or have the special tools (dial indicator) or the budget for a gear swap.
Another factor for me not swapping gears, was my 258 was tired.
Had I swapped gears, I would have spent more $$$ to get the 258 healthy.
In the long run, I scrapped my '81 after I used it for a donor for the '86 I had.Bryan Smith
1986 Jeep J20
1982 Jeep J10
1981 Jeep J20
Originally posted by addictedIf the 6 isn't quite enough with the horrible factory gearing in it it will be a whole lot cheaper to change out the gears than do an engine swap. If it were me i'd snatch it up and run it as is and change the gears if I needed to down the road. I bought an 82' with the 258 and T176 4 speed with 2.72:1 gears and it got up and went as well as the 89' with the 360 and auto. The auto will definatley rob some power though.Originally posted by jeepdreamerOk,
IMHO, a 258/727 is a less than desirable combo for a FSJ.Bryan Smith
1986 Jeep J20
1982 Jeep J10
1981 Jeep J20
