Old 06-17-2019, 04:52 PM
miamitj miamitj is offline
Help needed finding a side window gasket on '76 Cherokee
So I'm in the middle of the restoration of my '76 Cherokee when I realized the weatherstrip kit I was getting does not include the long side window & its small vent window.
Any thought on where I can find one? The existing one is beat pretty bad...
Old 06-24-2019, 12:00 PM
subscribing. I am not sure and haven't seen them. Hoping someone else has. Mine could use some replacing too.
Old 06-24-2019, 05:32 PM
I had a set I gave to a local used jeep parts place called amc salvage in Glendale Arizona, they were in very good shape but that was years ago, they may still have them?
Old 06-24-2019, 07:03 PM
I would think with the low demand OEM type one-piece aren't avail anymore. I'd check with a shop that does RV/trailer work or a boat yard for cut-to-fit material sold by the foot. Our steel work boats used pop-out windows on the sides wheelhouse. Gasket material was easy to get at a ship yard. The private tupperware fleet, fiberglass pleasure boats also use a lot of pop-out cabin windows. Shouldn't be too hard to find at a marine supply house or decent boatyard especially in FL. Bring a piece of yours in and match it up.
Old 06-25-2019, 05:52 PM
fsj454 fsj454 is offline
Long time member
Cargo side windows
If you are looking for rubber glass cargo area seals for flip out windows they are two piece one for the solid glass and one for the flip out window on a 1976 Cherokee. I have two rear portion windows and rubbers please contact me if interested so I can look at condition
window fell into door 1978 Cherokee BlackSpruce General FSJ Tech 9 02-18-2016 06:58 AM
Rear and side window tune up... Geminiroq General FSJ Tech 4 08-21-2010 02:30 PM
where can I find door seals and side window seals for 1970 j-100? joescarshack General FSJ Discussion 8 08-08-2010 07:59 PM
Cherokee side window, reversible? Rhino Racer General FSJ Tech 13 09-15-2007 10:44 PM
Changed passenger side exhaust manifold gasket jeepthing General FSJ Tech 2 06-20-2003 12:50 PM
