Ive had this problem before but this is different! last time it was a bad ground on one of the bulbs, but all of the lights worked. This time the headlight switch is clicking and only the front lights are flickering along with the cluster, the rear lights are out, but I still have brake, tuen signal and back up lights with the headlights off. Here is what I have done so far:
Replaced headlight switch. When I did this I noticed that a white wire that leads from the headlight switch to the fuse cluster was hot. Checked fuse, was good, replaced anyways, nothing changed.
Traced white wire from the fuse cluster on the engine bay side to the front lights i.e side markers and turn. These wires were not hot and appeared ok. Removed headlights and front turn and side markers to inspect.
Pulled off fuse block from engine bay side and nothing looks out of the ordinary.
Checked all fuses with test light, all are good, except for the fuse for the panel lights, when you put the probe on that one it flickers with the headlights.
Removed rear lights and checked for grounds, all appear ok except they are not on. Do have turn signal and brake lights even with the headlights on but nothing else. Interior lights flicker somewhat with the headlights on but not completely bad.
Any thoughts and ideas are appreciated!!
Thanks!
Thanks!
