  #221
Old 09-22-2020, 09:06 PM
cu4whln's Avatar
cu4whln cu4whln is offline
Hitch Day .. UGH
So, I was originally never going to tow anything with the 401.. but that has all changed with the RT 66 trip and new engine.
So, I recovered my original factory hitch and wiring from my buddy who "stored" it for me for 5 years! lol [ Thanks Dan ! ]
I figured this would be a no brainer, easy .. NOPE.
I forgot this thing is made from 1/4 thick steel.. It is heavy !! Dang.
I had a ton [ pun intended ] of trouble holding this thing up and trying to install it.
Almost smashed my face when I lost control of it.. uh oh.
[IMG]http://[/IMG]
Then, after fighting it "almost" into position.. I saw that the new tailpipe was going to interfere with the hitch. Dammit!!
So out comes the cutoff wheel.. and much cutting later, removed the small section that would hit... THEN had to fight it back into position and bolt it up.
I was so beat after this, I didn't even bother with the wires yet.. Anybody have details on this? Specifically, the large wire with the black connector on it?
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 09-22-2020, 10:36 PM
78 WIDETRAC's Avatar
I just unplugged my towing box from the 79 chief. It plugs into the factory harness. at least mine did. I don't remember a plug that looked like that though. If it wasn't dark out I go crawl under it and get a pic.
Old 09-24-2020, 01:31 PM
cu4whln's Avatar
Please do! I "think" this may be a feed for a brake controller? idk really...
Also, note the in line single plugs .. are they really just connected together like this?
Maybe a pic of all the connections please ??
TIA ..
Old 09-24-2020, 03:23 PM
I hope these help.
This is a pic of the box plugged back in line using the factory harness.
This is The tow harness removed and the harness reconnected.
My wiring is a mess under there but here is a pic of it and the connectors some factory some not.
We seem to have the same hitch. My jeep had the 2nd fuel tank. I had to remove it because it was full of rusty gas.
This is from the 79 Chief.
Old 09-25-2020, 01:09 PM
Mine looks exactly the same as 78 WIDETRACs. Same hitch, same electronic box, same connectors. I also had to trim my hitch to fit my exhaust. I have a spare tire hanging in my mine, though. The relays in that box are REALLLLLY loud. I can hear them clicking more than the clicker under my dash! HAHAHA!
My understanding is all that box does is separate the trailer light power from the Cherk harness so when you plug a trailer in, the blinkers blink at the same frequency and you don't blow fuses when you turn the lights on.
I also have a thick blue wire under my dash that is not connected to anything and a 2 pin connector under my cargo area that has that blue wire and another one (maybe ground?). So all the wiring is there for a 7 pin RV style connector/brake controller but I am 90% sure the electronic brake feed does not go through the box.
Old 09-25-2020, 01:49 PM
bigwalton's Avatar
bigwalton bigwalton is offline
Originally Posted by cu4whln
I am never going to tow anything...
I do know I will not be towing anything.
Just going back through this entire thread and had to quote this
'77 Cherokee S 4-door - 401/EZ-EFI - patina driver
'84 Alaskan Postal CJ-8 - RHD fun driver/trail rig
'98 TJ - DD
'05 Rubicon LJ - DD
'18 Renegade - DD
Old 09-25-2020, 02:43 PM
bigwalton's Avatar
Just a thought, for what you want to do, why not wire in a new plug socket and brake controller? I know it's $$$, but I would feel a lot better with new stuff from the battery/brake pedal to the trailer and take all that old stuff out of the loop.
I did a Redarc controller and one of the sockets that has both the 4 and 7-wire options when I redid my camping trailer on the Postal. The socket alone was worth it to make hooking up ANY trailer a breeze and you don't need to ever worry about adapters. Of course you don't need to redo ALL of the wiring to add that kind of socket, but I like your do-it-right-once thinking here FWIW
'98 TJ - DD
'05 Rubicon LJ - DD
'18 Renegade - DD
Old 09-28-2020, 08:35 PM
cu4whln's Avatar
Yea, yea .. lol
So, a modern trailer wiring upgrade might be the way to go... The original factory one has relays for all the trailer lights. Seems to be overkill with modern led lights with little load.
I do need a brake controller anyway.. and not sure the 77 design supports electric trailer brakes.
Did you tap directly into each feed for the lights then?
Old 09-28-2020, 08:39 PM
cu4whln's Avatar
Whoa! Hmm, NOW I read this... Hmmm
The blue wire should not go through the box.. it sends the signal from the brake controller I believe. Now I need to rethink this situation.
Time to look for that under dash blue wire and get out the multi meter !!
Old 09-28-2020, 09:04 PM
bigwalton's Avatar
I did, I'm running LED taillights/turns on the Postal so I already have a digital flasher unit and the trailer is LED as well.
I simply go overboard with anything to do with towing/trailers, that's why my little camp trailer has brakes and all the wiring related to it is brand new.
'98 TJ - DD
'05 Rubicon LJ - DD
'18 Renegade - DD
What's a SUPER Chief - OLD TOPIC MESS UP...REPLY HERE! testuser General FSJ Tech 10 12-06-2015 11:10 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
Cherokee vs. Cherokee Chief ??? Jeff in north Texas General FSJ Discussion 6 07-19-2008 09:54 AM
1977 Cherokee Chief - Lea Adams Dome Cherokees 0 08-21-2005 11:45 AM
