Old 06-15-2018, 04:46 PM
Curly5759's Avatar
Curly5759 Curly5759 is offline
Quadratrack question
Cliff notes version, longer below: Can the large plastic thrust washer behind the drive sprocket break apart and get ground up enough to disappear?
I recently purchased a QT as a spare. The clutch cones were bad and one of the cones had no teeth for the drive spines. I think it had regular ATF in it instead of QT fluid.
As I reassembled it to put on the shelf, I noticed the large plastic thrust washer that sits under the drive sprocket was not there. The t-case had obviously been used from the amount of grease/dirt on the bolts, I was the first to disassemble it in a long time. I never saw the washer, didn't move any parts off the bench and I'm the only one who uses the shop. I saw no signs of metal to metal contact between the drive gear or the case and no signs of it in the case. Is it possible for that washer to simply break apart and get ground into nothing?
77 Cherokee S 360/TH400/QT
Old 06-16-2018, 12:13 PM
or someone forgot to put it in the last time it was opened up. I have a rebuilt quadratrac with part time kit and spares also if needed
Old 06-21-2018, 05:50 AM
QuadraTrac
I have seen the inside of many QTs. A few of them were missing the thrust washer but never saw evidence of one being chewed into nothing. I've seen the tabs broken off however. The drive sprocket will eventually grind into the back half of case when it is not there.
Another A/C Question: York or Sanden The PIG Smith General FSJ Tech 27 07-03-2018 04:29 PM
1 PS question, 1 eletrical question SamW General FSJ Tech 2 01-15-2011 12:31 PM
Quick 85 Grand Wagoneer Question WagoneerMan General FSJ Tech 3 01-31-2010 11:06 PM
Quadratrack question on '79 cherokee JNErotten General FSJ Tech 17 11-09-2001 04:19 PM
