Old 04-04-2020, 07:33 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
Main Seal Leak HELP !!!
newly built motor
shop that installed and machine shop have tried at least 3 times
to replace the rubber main seal
each time they were very careful
and did things as right as rain
but still leaks
they said they made sure all valleys etc were clean
( hope I am using right terms )
has anyone experienced this
that has advice ?
thanx
dave in NC
Old 04-04-2020, 08:01 AM
probably not the rear seal. if the rear oil galley plugs were not sealed they can leak out back of block.
Old 04-04-2020, 08:15 AM
can also be the rear seal on the intake manifold leaking down, and or valve covers, check both.
Old 04-04-2020, 08:33 AM
Full Size Jeeper's Avatar
How sure are they, it is the rear seal. Lots of other things above it could be leaking. Cam plug at back of block could be one. Are you driving the truck yet? Oil makes the seal swell, thicker than when it is first installed, you need to drive it. Where the two halves meet, a small amount of sealer is recommended.
Mine had a little, leak at the rear main seal. Was never a drip, just wet in that area. It went away once I ran it through a few heat cycles. What about the PCV valve, is it working. Are the piston rings seated yet? Do you have to much pressure in the crankcase. Good luck.
1978 Wagoneer
Mods:
Old 04-05-2020, 02:58 AM
gophman's Avatar
gophman gophman is offline
Yup I have replaced the rms on my wife's waggy 3 times in place and still leaks like a mother so since this summer looks like a bust I'll pull the motor to see if it's possibly cam gallery plugs (I'd had them out to clean).
The irony is my 360 in my pickup with a fresh build is pretty much dry and I reused the seal lol.
Old 04-05-2020, 08:19 AM
SOLSAKS's Avatar
thanx to all who responded
I will relay this to the shop
I will report back
dave in NC
Old 04-06-2020, 07:51 AM
There is a vacuum pump that can be hooked up to keep the oil from coming out.
Old 04-10-2020, 01:53 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Or they are not doing it right.
I put Permatex #2 on the outside circumference of the seal where it fits into the groove of the block and bearing cap, on both sides of the tabs on either side of the seal, and on the split ends where the two seal halves meet. I do that and I get engines that do not leak literally even a single drop of oil. The trouble is, it's very hard to do it that way with the crankshaft installed.
It can also be an oil pan gasket not done right. Pans get warped and messed up by idiot mechanics. For those I use silicone sealer where the rubber seals meet the cork gaskets.
Old 04-10-2020, 11:14 AM
Rear mains are typically pretty easy to keep oil tight. They used to use ropes for rear seals you know.
Old 04-10-2020, 01:56 PM
DarkMonohue's Avatar
Shakes hands with danger
Make sure that the PCV system is in place and functioning correctly. The rear main in my J20 leaked like a son of a gun until I replaced the PCV hose behind the carburetor. The original hose had collapsed and was allowing crankcase pressure to build up rather than vent to the intake manifold, and the crankcase pressure pushed oil out past the rear main seal.
The original formed hose is NLA, and the bends are too tight to easily make with bulk hose, so I cheated a little and used a long enough hose that it formed a big loop. That allowed it to connect at both ends without being pinched or folded on itself.
Back for another Rear Main Seal Biscuit5050 General FSJ Tech 10 12-26-2015 06:35 PM
Pcv valve and main seap oil leak gophman General FSJ Tech 8 06-03-2015 05:00 PM
New seal; leak is worse caionneach General FSJ Tech 8 07-16-2007 11:38 AM
True/False? Front main seal = crankshaft seal CustomWag General FSJ Tech 1 06-26-2007 04:27 PM
Trick for removing rear main seal...... billyrb General FSJ Tech 9 05-03-2003 01:24 AM
