Old 02-28-2020, 09:46 PM
Rusty76 Rusty76 is offline
Tell me your top wiring tips (my harness is in the mail)
This monday my BJ offroad wiring harness is due to arrive. I have zero know how on wiring. I know I will figure it out but getting some tips from you pros is always helpful. This is for a 76 Wagoneer. Rebuilt everything is in but I have not started it up yet. Decided I better replace the old patched electrical. I'm super excited to learn and work on this aspect of the build.
Thanks everybody
Old 02-28-2020, 10:42 PM
Shep 762 Shep 762 is offline
If it takes too much force you're doing it wrong. No need to horsef**k a connector, look for locking tabs, push instead of pull etc.
Old 02-29-2020, 01:17 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
No electrical tape. No adhesive tape in general. It turns gooey, makes a mess, and unravels with time. Use heat shrink or dry vinyl wrapping tape tied off at the ends.
No plastic sleeve connectors crimped in place. Use bare metal connectors. Crimp them to the wire, solder them to the wire, then heat shrink over. I really like the adhesive-lined heat shrink because it forms an airtight seal so no corrosion can form inside the wire and connector.
No splice locks. Hell no. Those are the worst things ever invented.
Tooth lock washers on grounding terminals. They cut through paint and corrosion to make good contact.
Proper bundling and wrapping to keep wire runs neat and organized is your friend.
Old 02-29-2020, 11:46 AM
Full Size Jeeper's Avatar
Take a lot of pictures of the layout of the old harness. Also draw out on paper the layout of the wires and any plastic hold downs or brackets that you take off.
Mark with tape the new and old connectors at the same time. You will think you can just remember where it all goes, but might forget something.
(example)
alt. plug A
alt. plug A
a/c plug B
a/c plug B
Once you get the old one out, lay one on top of the other and check length. Easier to mod the new harness on the bench if needed. Lots of up front work, but will make the install go smoother.
1978 Wagoneer
Mods:
Old 02-29-2020, 12:46 PM
Kaiserjeeps's Avatar
Get the harness in and make sure you have a permanent destination for each wire before you cut. Cut long, fit it, then cut one more time for a perfect fit. Doing it twice is way easier than trying to make a wire longer.
Epoxy heat shrink is the only way to go. You will need a heat gun. Don't bother with regular heat shrink. It does not seal moisture out.
Soldering each connector as previously mentioned will make a connection that will last a lifetime. Cover it with good heat shrink.
Document each wire color and where it goes. Start to finish. You will be glad to have that later if something starts acting up.
Invest in quality crimpers. REAL crimpers. Then crimp and solder and heat shrink away.
If you must use crimp connectors with no solder, only use epoxy filled heat shrink connectors. That at least seals the connection.
Do not use acid core solder flux. Thats for radiators and metal. Use rosin core flux only. Acid based flux causes corrosion on your solder work.
Cover wire runs with wire loom. The standard thing is ribbed plastic. For restoration uses, asphalt covered loom is available. For super heavy duty abrasion resistant covering, woven poly is out there for stuff like tractors.
For under body weather proof connectors, weatherpak can't be beat. That involves the special terminals, seals, connector shells and very important, the right crimpers.
The packard 56 connectors found on every jeep (older) out there are open and subject to corrosion.
I just built a complete new harness for an old dozer. I soldered every joint and covered it with heat shrink. Original wire colors and everything.
I have all the faith in the world it is as good as it can be. Do the best that you are able. It will matter later.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 project J truck FOR SALE
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 03-01-2020, 01:12 PM
67GMC's Avatar
67GMC 67GMC is offline
Second to soldering, I typically use the "western union wire splice" method of making joints. Then cover the joint with shrink rap. I learned this in high school electricity class.
Soldering is great if you have the wires on a bench. I've also seen a fair bit of poor soldering that causes sharp points that poke through the insulation and cause issues. Never had a western union joint come apart.
Agree that Scotch Locks (those blue plastic crimps) are products of satan and just designed to cause more problems. I had a Cherokee that the previous owner had installed a remote car starter/door unlocker. All Scotch locks everywhere. What a mess to fix in a tight spot under the dash etc.
My Stable:
1984 Jeep Grand Wagoneer, 5.9L, 4x4, Auto (newest project)
1997 Volkswagen Cabrio, 2.0L, Manual
2005 Kia Sportage, 2.7L, Auto
2006 Toyota Sienna, 3.3L, Auto
2018 Toyota RAV4, 2.5L, Auto
Recent projects (no longer with us)
1987 Jeep Cherokee Laredo, 4.0L, 4X4, Auto
1967 GMC 910, 283V8, 4SPD (RIP)
Old 03-02-2020, 07:57 AM
Great! Thanks everybody. Looks like I've got lots of research to do before I start.
Hopefully install new tank today and start plugging away at the wiring.
Thanks for taking the time to help. Look forward to updating this thread with success.
Old 03-02-2020, 09:00 AM
My approach is similar to Nigel's.
To make a solid, weatherproof splice:
Uninsulated butt connectors. (Del City, Waytek)
Good crimping pliers. (Amazon)
Automatic wire strippers (nice to have - Amazon).
Kester 60/40 or 63/37 tin-lead rosin core solder. Fairly large size, like 30 or larger. (Amazon)
Weller soldering gun. (garage sale or Craig's list, or Amazon I suppose)
Extra paste or liquid flux for old wires (Kester brand NLA, use MG - Amazon).
3M adhesive heat shrink tubing (Parts Express, Waytek, Mouser or Digikey).
Cheap heat gun (I have a nice green one from Grizzly in the garage, plus a small one on my indoors bench; Amazon, Harbor Freight, others).
No cheesy/gooey plastic electrical tape.
Practice on scrap wire.
Be sure to put the heat shrink on BEFORE you crimp the connector.
Hot iron, get in, get out. Let the work melt the solder.
Adhesive heat shrink FTW.
I like to bundle everything in split loom and secure with black tie wraps aka zip ties (Parts Express). You can buy "automotive grade" split loom which has a higher melting temperature, but I have used the cheapest split loom I can find and had no issues. You can also buy the tees for split loom that the auto manufacturers use to branch split loom, but I think that's mostly to make the installation fast on the assembly line. I just bring the wires out of the split and put a zip tie around the loom to keep the wires from unzipping down the loom, then start another piece of loom.
Use NEW shakeproof washers (aka toothed or star washers) and a dab of dielectric grease on ground connections.
Do own a multimeter? Suggest you get one and learn to use it. An exceptionally powerful and useful tool.
Old 03-02-2020, 04:45 PM
levelhead's Avatar
levelhead levelhead is offline
All good advice
1988 GW (2)
1980 Cherokee Laredo
1979 Wagoneer
1976 J10 401
1977 Wagoneer 401
1977 J10 4 speed
Old 03-05-2020, 09:14 PM
Wow I've been doing loads of research and I had no clue about the Solder Vs Crimp debate. Literally changes in every article.
Old 03-08-2020, 07:36 AM
There are opposing views.
Solder makes a good joint whether you crimp well or not. The argument against is - it's more work, and the transition from solder to bare wire is a stress riser that can fatigue the wire at that point. As you know, you can break copper wire by bending it back and forth repeatedly to cause fatigue. This is why they use stranded wire in automobiles - the individual strands can bend more easily without fatiguing. Solid wire is used in buildings because it's immobile in the walls.
Suggest if you solder, put your joints where the wire is not going to move a lot, or tie the wire down, or both. The heat shrink also helps to stiffen the joint, and avoid fatiguing the wire.
A well-executed crimp is said to be as good as a joint electrically as a soldered joint, maybe better. Supposedly the extreme point pressure of a proper crimp welds the two materials together. However, specialized crimping pliers that can make these excellent joints are expensive, and only work with specific connectors.
Soldering is still used everywhere in electronics. Indeed, it seems like industry has gotten away from mechanical wiring like wire wrap (popular a couple of decades ago) and moved instead to tiny surface-mount components that are held in place by only solder.
If you really hate the idea of soldering, suggest you get the adhesive-lined plastic insulated butt connectors, and buy a ratcheting crimping tool made for those connectors.
Old 03-16-2020, 07:58 PM
Thanks again for the help. Ok I've pulled out the old harness and ran the new EZ wire harness to the designated spots (engine, front, back, dash, steering column).
I will admit I was pretty overwhelmed after taking the old harness out. It crossed my mind that this might be the step of this build that never allows her to move under her own power. After I sent the wires to designated spots I feel better and am up to the challenge. So the first round of questions.
1. Some of my old connections such as the Temp Sensor has the push on style.
Does a guy just use the ring connectors with heat shrink and a small nut?
2. So it looks like I snapped a bunch of pins from the ''Pin Connection" and a couple
other ones from the gauge cluster. Initially I took this as a sign that I should buy
a sweet new Dakota Digital cluster. After a quick price check I quickly decided I
should try to fix. Can I get new pins? I read a good thread about how to fix.
looks doable.
I had this whole week off to wrench and maybe finally get this thing running before the snow melts. My little ones have been sent home from school. So daddy daycare starts tomorrow. Might start with some wiring. IMG_0712 by , on Flickr
IMG_0713 by , on FlickrIMG_0714 by , on FlickrIMG_0715 by , on Flickr
Old 03-16-2020, 08:05 PM
One more question. I bought the larger harness for my 76 Wag. It has lots of extra wires such as power locks, windows. The instructions mentions just to cut it off as close to the fuse box as possible. Am I reading this right? Wouldn't those cut wires be hot? Maybe cause a fire? Thanks again!
Stay Healthy everybody..
Old 03-16-2020, 09:18 PM
chubbinius's Avatar
You can either work on re-attaching the pins, or pick up a new circuit board here
https://stores.partsdude4x4.net/circuit-board/
They also have a replacement pigtail if you can't get the pins out here
https://stores.partsdude4x4.net/inst...uster-harness/
Hope that helps. On the cutting off the extra wires, I would recommend that you just wrap them and secure them rather than cut them off...that way if you want to upgrade or add a circuit later, you have the wires to do it.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 03-17-2020, 08:40 PM
Hi thanks for the tip. Called Partsdude today. They don't have the board for my 76.
Too bad that would have been perfect. I think I'm going to try and fix the pins.
Found a great thread about using super small screws to act as pins.
I started separating the front light wiring from the engine bay wires.
The organization was a big help is thinking I just might pull this off.
With lots of help from this forum. Which I'm lucky to have found.
Stay healthy everybody.
Old 03-18-2020, 10:43 AM
You can probably find a used board from a wreck/part-out if you don't want to repair what you have. According to my parts book, the '76-80 boards are all the same - maybe later too, but my book ends there. I have repaired some of these pins (the straight connector, not the round one) by putting a piece of solid copper wire inside the pin and soldering to the board. You could also fly around the connector with short wires that go direct from the harness to the board.
The push-on pigtail is available if you can't reuse the ones from your old harness - I found a couple of sources recently by searching the net. I would just snip off the old connector plus a couple of inches of wire and splice it to the new harness.
The wires won't be hot if you leave out the fuses to those circuits. I would leave a couple of inches of wire and cut them off. Splicing the wire back on to the harness, should you need that circuit, is trivial. You should cover the cut end of the wire with something. They make heat shrink caps specifically for this purpose.
Old 03-20-2020, 07:12 PM
Thanks Tgreese for all the great tips. Still not sure which way I will fix that board. I like your method and the other one using small screws. Got lots of work in front of me first. Made my first connection on the engine today. Started with two easy ones. Temp sensor and Oil sender. Its early but I think I will like the process. Of course on my very first connection I forgot to put the heat shrink on! haha..
The next few will take sometime. Basically goes like this.
Read wire "Alternator Exciter", spend 20 mins figuring out what it does.
Another 20 mins where it goes. Another 20 mins checking my work..
Slow process but learning lots. Sure would be nice to find a local guy to toss some crinkle his way for a little mentoring.
Old 03-20-2020, 08:11 PM
You are doing it right, take your time, it is not a race. Glad to here you are getting after it!!!!
1978 Wagoneer
Mods:
Old 03-25-2020, 06:46 AM
Soldering is an option but Truthfully a properly Crimped connector is a lifetime connection. A lot of Engineering has gone into designing Crimped connectors. For example: all the connectors from the OEM are crimped. In the older days there were some soldered splices but not now. However, the Plastic Sleeved crimp-on connectors are Junk. Use the metal crimps with water proof/adhesive line shrink wrap. I sometimes use liquid-tape under the shrink wrap.
Old 03-26-2020, 07:19 PM
Hey Everybody hope this finds everybody healthy. I'm working away here on the 76 Wagoneer, installing new wiring from EZ. ITs proving to be a little harder than EZ.
hahaha. I'm very new to this and its slow but I'm enjoying it. I had a experienced buddy lined up this week to come help but with everything going on decided its best to work solo. I'm confident I can wire the rear and front of the wagon but I'm struggling with the engine. Even with the TSM, Haynes and the internet I think I would be further ahead if I just ask. Also hope I don't offend anybody but I'm going with crimped connections. Picked up the good connectors and proper crimper. Just seems easier to not screw up. Oh soooo many questions. Hope you find some comedy in this!
Alternator:
OK I have 3 wire type. From what I've deciphered I get
where EZ wire 'Alt power' goes. I also learned that the 'Alt Exciter'
connects to one of the male connectors on the Alt.
The last wire original green colour is the voltage reader, I don't seems to have
one of those in my new harness.
1. I guess I just add this wire in. Run it from the fuse panel to the Alt?
I'm going to list every wire that I need to run.
IGN Switch Start Wire: I don't think I need this one because I'm running larger gauge wire from started solenoid directly to started?
Solenoid Power Wire: Must go to solenoid but not sure where?
Fan Wire: This must be for electric fan. Which I don't have. Not needed.
Coil Pos Wire: I think because I'm using a DUI distributor I can forget about this wire?
AC compressor Wire: AC compressor has been removed by PO. I will deal with that wire later.
OK hope everybody is following along. Lets talk about my DUI distributor.
Sounds to me that I need to run a 12 gauge wire from started solenoid to BATT connect on the distributor. It also has a TACH connector, I guess I run the Tach wire to this.
Where on the solenoid does the DUI BATT connection run to? Can I use the big read Solenoid red wire for this?
Also I understand that the Dui distributor has its own Coil and module built in.
Does this mean that I can forget and remove. Coil, and both those boxes on the passenger fender. The electronic ignition box and the module box
To make a confusing post maybe less confusing I have no idea what I'm suppose to do with.
Solenoid Power Wire
Also '' Neutral Safety Switch" I get what it does but where is it and how does it get wired up?
I'm sure most guys can wire these things up blindfolded. I hope to learn that much someday. Here are a couple random pics. With the kids off school I've been working on the rig from 5am to 7am and again from 8pm to 10pm. I dream about getting this thing on the road and cruising with the fam. Checking out new places in the mountains..
Stay healthy everybody and thank you very much!!!!!!
IMG_0748 by , on Flickr
IMG_0747 by , on Flickr
IMG_0745 by , on Flickr
IMG_0744 by , on Flickr
IMG_0743 by , on Flickr
IMG_0741 by , on Flickr
86 waggie wiring harness in 87 J10? ijess1 General FSJ Discussion 6 09-06-2015 08:40 PM
TBI Wiring Harness Adaptability taklbury Fuel Injection 2 12-03-2011 06:28 PM
NOS FSJ Dash wiring harness .... no part # red mistress General FSJ Discussion 4 10-25-2009 05:53 AM
what wiring harness fits? supercopjason General FSJ Tech 2 08-14-2006 09:10 AM
Wiring tech - dashboard harness - Crackpipe build Sitting Bull General FSJ Tech 7 05-18-2006 07:55 PM
