Old 02-07-2020, 12:30 AM
argonaut argonaut is offline
1972 Wagoneer Tapered or Flanged Rear Axles?
I'm looking at buying a 1972 Wagoneer and I'm wondering if that year would still use the tapered axle shafts/hubs for the rear Dana 44, or if it would have flanged axle shafts.
The wheels have hub caps on them so I couldn't see the end of the axles to check.
Thanks!
Old 02-07-2020, 11:04 AM
99% certain flanged.
The change was not associated with any specific year AFAIK, but I believe the flanged axles started appearing in the 68-69-70 time frame. A '72 should definitely have a flanged axle, and a TracLock if equipped with limited slip.
Old 02-07-2020, 03:08 PM
+1
Flanged
Old 02-09-2020, 01:12 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Absolutely positively a flanged axle 30 spline Dana 44 offset differential.
Standard ratio for V8 automatic was 3.31, optional 3.73.
Early Wagoneer rear hub issues CarlBraun General FSJ Tech 11 06-26-2013 08:57 PM
chevy axles in wagoneer w/ t400/qtrac slimbailess Off-Road FSJ Tech 1 01-19-2008 10:39 PM
