Old 04-23-2020, 04:19 PM
Cliff's Avatar
Cliff Cliff is offline
Non-Vented Fuel Tank
My 77 Cherokee has no fuel tank vent system. After a drive on a warm day the tank builds pressure and opening the fuel cap allows the pressure to escape. I assume this is common since the gas caps sold by BJ's actually have a pressure warning on the cap.
At some point this pressure has to cause problems. A long drive on a hot day must build lots of pressure. It used to be that cars had vented gas caps before manufactures turned to vent lines and charcoal canisters. Is this a common problem with FSJ's in general, and not a big deal?
Cliff Danley
1977 Cherokee S
Old 04-23-2020, 06:15 PM
you need a vented fuel cap.
Old 04-24-2020, 03:40 PM
No vapor recovery in 1977 for full-sized Jeeps delivered in the 49 states. California cars and trucks had it. This is shown in the online TSM for 1977, free to read and download. Jeep took advantage of the rules and made the GVWR for all the FSJs above 6000 in this era. The rules were more lax for heavier rated vehicles then.
Yes, you need a vented cap. I use a locking cap that came with my '77. It may or may not be intentionally vented, but it's loose enough now that it does not matter.
Old 04-25-2020, 01:34 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
That is so crazy. I can tell you that every 1972 Jeep, even down to the CJ5, had a vapor recovery system. Some used canisters and some just vented the gas tank into the engine crankcase, but they all had a sealed fuel tank. The GVWR thing came along later. It's just comical.
fuel injection stock fuel tank Lake Ripley Fuel Injection 5 07-12-2016 10:19 PM
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
1978 Ford Bronco 25 gallon fuel tank swap in J10! msh227 General FSJ Tech 8 10-16-2009 04:33 AM
69 Waggy Stalls When Warm kodyharrell General FSJ Tech 11 09-30-2009 11:07 AM
I guess it's getting hot.... Belteshazzar General FSJ Tech 3 04-22-2009 10:02 PM
