Front Bumper build, Rock lights, Winch Mount & Pics
exceptional work on the bumper Metal Twister. I also would prefer one a bit taller ,but thats just preferance. My aim isn't so good and more metal would decrease damage elsewhere
Here in the So Cal deserts its not too brutal. I am building this for cross country adventure runs in our local deserts and didn't see the need for battering ram, More ground Clearance at the attack angle was more in my way of thinking when designing it. It was a fun relaxing build and have some ideas on a rear bumper that im anxious to get started on. I think I want it to wrap all the way to the rear of the rear fender flairs and act as a slider at the same time. Might look a little goofy until I get the semi exo cage/ roof rack tied in to it but I will post the pics and take the abuse anyway. And thanks for the props on the work, Best thing a fabricator could hear!
Very cool. What size tube did you start out with?
Do you have any pics on how it moutned to the truck? Looking at my mounts today, I beleive you trimmed the ends of the frame off to push the bumper closer to the grill. I am curious to see how you mounted it.
tHanks!
Dan Stewart
1958 Land Rover Series 1
1991 Wrangler YJ
tHanks!
I just removed the original bumper mounts and bolted this up flush on the cross member with 3 0 1/2" grade 8 bolts.
And here is a pic of the side just being held on with one bolt at the time of the pic.
LOL, Everyone is different with different tastes, thank God!
You will have to save up and buy the cliff hanger and make it narrower... Im not in that business.
VERY nice work! i initially thought it would be too small, but now its finished i really like the look. nice and compact to keep it from plowing on the rocks. nice job.
The 1 st pic below is what has me currently doing AutoCAD Donuts...
Obviously you have holes drilled in the support plates for something and
it must be something other than that particular year frame I would assume since there are no bolts in them. No matter...You did this...
The connection to the frame w/o using the weak OE bumper brackets is what I have been chewin' on. I am "attempting" to draw the front portion of the frame on my 79' J10 so when I do go to make a bumper I can easily draw these supports and have them cut via water jet. It is a b1tch... Here is what I have so far, I can "Plot" this 1:1 and then cut it out with sizzors and use a leather punch to punch the 3- .5" holes in the triangular pattern, insert bolts thru the frame then slip the paper cutout over the 3 bolts. SO I am taking the 1:1 cutout paper and lay it against the frame and much of this is DAM CLOSE, it is a work in progress, the 3 triangular holes I have nailed. I need to figure out how to measure back to the 2 threaded bolt holes that are OE on the frame L and R, then dim them X and Y in relation to the front 3- .5 holes and then connect the dots so to speak so I end up w/ 5 bolts holding EACH side ( Plus other things like a support between the triangular holes at the very front) It is HARD...
