Old 01-13-2008, 03:11 PM
Warmachine's Avatar
Warmachine Warmachine is offline
New Radiator and Fans *with pics*
After going through a series of donor radiators in the Green Weenie, I finally broke down and had the local radiator shop order me one. Figured it was the best chance I'd have to get my dual fan setup made as well.
Quick fabbed a shroud for the two 12" fans, painted it up, slapped it in.
Crap cellphone pics:
For now I'm running it with both fans manually switched.
Both fans off for extreme cold morning start up (Iowa=frigid)
One fan on for daily driving, second as a helper for this summer
Thermal switch should be in soon to replace switch for the second fan
Not a bad day spent in the shop, I'm pretty pleased with the results thus far.
Mike Wood
Resident alien and thread killer!
Old 01-13-2008, 03:45 PM
Looks nice. Can't wait for the write-up....
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 01-14-2008, 06:20 AM
Warmachine's Avatar
I should have a dimensioned drawing done soon.
As far as a writeup...get some 1/8" material (in my case), cut to size, drill a few holes, weld some mounting points on...paint and enjoy! lol
Mike Wood
Old 01-14-2008, 12:41 PM
710 Burner's Avatar
Ah, yes, dimensia. I have heard that happens to FSJ owners.
Mark B. Jones
Old 01-14-2008, 12:56 PM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
What fans did you go with? Out of? looks good!
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 01-14-2008, 12:59 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Is that a 4 core?
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 03-13-2008, 09:58 PM
GWDriver's Avatar
GWDriver GWDriver is offline
How many amps are they drawing?? And do they keep the coolant cool???
LarryD
USMC Retired
Good Lovin', Good Beer, and a Grand Wagoneer. What more could one want?
1984 Grand Wagoneer My therapy
1988 GMC Suburban soon to be retired. . .SOLD
2006 Hyundai Sonata GLS/LX Wifes DD
2003 Dodge TD 4x4 long bed
Old 03-14-2008, 02:32 AM
energyhutch's Avatar
energyhutch energyhutch is offline
I feel like this is a really dumb question, but I am admittedly a novice. With the manual fans, do you set up a switch inside that legs you regulate? With the auto fans, how and where is the setup which determines when they (or it) kick on? Thanks guys -
-Hutch
1994 Cherokee, the daily driver ...
1976 Wagoneer, 401 complete with original vacuum disaster and electrical nightmare, both of which have been fixed prior to the sale of this rig
1978 Cherokee, " Roadie " recently driven back from Phoenix to Texas ... no trailer involved!
Old 03-14-2008, 05:12 AM
yankeedog yankeedog is offline
Pretty cool (pun intended)Betcha you had almost as much fun as a day of fishing.
Old 03-14-2008, 04:22 PM
Warmachine's Avatar
Just some spare fans I grabbed from work. Was going to go with one 17" fan, but thought the two 12" would work a little better.
Mike Wood
Old 03-14-2008, 04:41 PM
Warmachine's Avatar
Originally Posted by Lindel
Is that a 4 core?
Nosir, OEM 3 core.
Mike Wood
Old 03-14-2008, 04:46 PM
Warmachine's Avatar
Less than 15amp per fan...haven't actually checked them, but they aren't popping the 15's I have each running through. Doing a good job thus far, and I haven't had a need to kick the second one on yet. Warmest it's been here was 60 degrees, so I shut the fan off, let it get hot....kicked the one fan on and it took it back down to thermostat temp.
Semper Fi
Mike Wood
Old 03-14-2008, 04:55 PM
Warmachine's Avatar
I have them setup to a 3 position switch (On-Off-On). Right "on" powers on the passenger side fan (fan#1 relay). Middle is both fans off. Left "on" powers on both fans (fan#2 relay and a diode to fan#1 relay). The switch is powered from a fused 12v ignition switched source (that way whatever fans are running shut off when I kill the engine). Everything is running manual until I can find an automatic setup that works with my sending unit...for less than $150 bucks! Otherwise everything is fuse protected at every possible point...I over-do the fusing...can't hurt LOL
Mike Wood
