10-03-2005, 01:44 AM
what do you use to seal the headers on. Is there a specific torque they have to be? Any thing that would make this more difficult than i expect? Could someone please give me some information on installing aftermarket headers.
it is the J in my signature
New Addition: 1982 Cherokee W/T
Engine: AMC 360 w/ Edel intake, 1.6 rockers, Class III cam, Comp pushrods, Holley truck avenger carb, headman headers, custom built exhaust
Suspension: 6" Lift 1" shackles up front
Axles: D44/AMC 20 w/4.88 and detroits
1985 Grand Wagoneer 360/727/229
TFI upgrade, 70k orginal miles will trade for the right j-truck.
10-03-2005, 03:19 AM
I used 12 pt ARP header bolts and lock washers, copper header gaskets. Also apply anti-seize to the bolt threads. I tightened them down when I put them on and then retightened them 2 weeks later. Since then no leaks...been over a year.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
10-03-2005, 03:54 AM
I was on a website called "headers by ed" who claimed the reason most aftermarket headers leaked was because of the small raised bead around the port on the header flange. His claim was that as you tighten the header bolts you pull one side away while pushing the other in and the resulting unevenness in pressure against the gasket results in the leak. His fix is to grind this bead flat to the flange and install in the normal fashion. i will be trying this soon as I have had a fair amount of problems getting mine to stay sealed even after retightening and locking bolts/washers etc. Just my $.02 worth.
10-04-2005, 02:33 AM
I used the remflex gaskets I ordered from BJ's offroad. They seam to be holding up pretty well so far. This was one of the first problems that has stayed solved so far. They are very thick though. Cost about $50.00 with shipping but beats doing it over and over every 3 months. So far so good.
2001 Subaru Outback 3.0 - Mamas assault vehicle
1989 Grand Wagoneer - DD and Boat Hauler
1985 Mercury 115hp inline 6 outboard
1989 Champion 184DCB - Bass boat
10-04-2005, 02:50 AM
Stage 8 locking fasteners. Do a search. I use them with Edelbrock headers and highly recommend.
Don
82 Cherokee
89 Grand Wagoneer
84 CJ7
10-04-2005, 04:28 AM
where can i find the locking washers and the stage 8 locking fasteners?
10-04-2005, 04:57 AM
Summit Racing or Jeg's sell them.
Thread Tools |
Display Modes |
