Old 12-26-2011, 07:36 AM
snuffleupagus's Avatar
snuffleupagus snuffleupagus is offline
Engine Hood Weatherstrip.....
Simply put.....Should there be some sort of rubber seal along the window side of the engine hood?
The beading water on wet mornings seems to dump a ton of water onto the electricals under the hood if I don't wipe it down first.
Big Birds Imaginary Friend........
1986 Jeep Grand Wagoneer.
AMC 360
Old 12-26-2011, 07:58 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
Yes, there is a thin strip of rubber on the cowl but nothing on the hood to stop water from running into the engine bay.
Originally posted by Ristow
i bet it was Simon....
Old 12-26-2011, 10:58 AM
blakeusa's Avatar
blakeusa blakeusa is offline
Yes I think BJ's may sell a reproduction. It;s basically a 1 /12 inch flat rubber strip (with a little rise in it). That gets screwed down to the body with some S type clips.
But the water - where is it coming from? This seal may be more to stop metal/metal vibration and not a water tight seal. I may have an extra one around... or can take a pic for you.
B
1971 J4000 Gladiator w/AMC 401 Restoration Project
Old 12-26-2011, 03:34 PM
It's not a leak.....If that's what you're assuming. Just in the morning or after a rainy night. The beading water settles and pools up on the hood. I generally check my fluids every other day or so. When I open the hood. It floods the engine compartment with water. I'm just waiting to hear a "snaping and crackling" from some sort of electrical component. Radio, heater motor..etc. Not a big issue.
AMC 360
Old 12-26-2011, 03:48 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Even if you have the weatherstrip on the cowl that seals between the cowl and hood, it still will dump water into you engine compartment when you raise the hood.
All the weathestrip does is it prevents hot air from the engine getting sucked into the ventilation intake under the windshield.
Old 12-26-2011, 04:35 PM
So it's just poor engineering on behalf of Jeep Wagoneer INC.
AMC 360
Old 12-26-2011, 06:01 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
it's called a Hood to Cowl seal:
http://www.bjsoffroad.com/prod-706.htm
$12.75 with IFSJA discount
BJ's Off-Road
ryan@bjsoffroad.com
Old 12-26-2011, 08:26 PM
blakeusa's Avatar
This is what BJ's Sells. This attaches to the body where the hood comes down closest to the window with flat S type brackets.
Also just looked at my truck. Where the back of the fender attaches to the door jam at the top of the engine bay it appears there is a separation that would allow water to drain out.
Maybe this is filled with dirt, mud whatever.....
Otherwise there is no drain's in the fender wells or seams.
Post a pic of where your water is pooling. B
Old 12-26-2011, 09:46 PM
texasskeeter's Avatar
texasskeeter texasskeeter is offline
WOW!! Dejavu!! I remember seeing this around 6:01pm.
Old 12-26-2011, 10:14 PM
He's refering to the water that stays on the hood after it rains. Then when he goes to open the hood all the water on top flows down and back and all over the wiring harness on the firewall and engine. It's just how it was designed. When I do it with mine after its been running I get a bunch of steam from the hot engine/hedders too. Nothing you can really do about it.
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 12-27-2011, 12:22 AM
oldyellowwagoneer oldyellowwagoneer is offline
Wax the hood real well, park truck facing slightly downhill ,PROFIT!!
(Of course you may need a slightly steeper downhill or a couple chunks of wood to drive the back tires up on to counteract any wag sag)
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
Old 12-27-2011, 08:45 PM
blakeusa's Avatar
Oh I get it now.
Grow some rust. Let it settle and make little holes.
Problem fixed.
Old 12-28-2011, 12:52 AM
BGW's Avatar
BGW BGW is offline
I don't think it's poor design. How else would they do it? All of my other cars do the same thing, a honda, yota, and vw. They all dump the water onto the engine if you raise the hood when it's wet.
1991 Grand Wagoneer, Stock, 99k.
My buddy Sam: "...as far as gas money goes Peter's car is as thirsty as an alcoholic on St. Patricks day..."
Engine Tuning Attempt JohnIL General FSJ Tech 11 09-10-2007 06:52 PM
New engine, old carb, hard starting JohnIL General FSJ Tech 0 07-27-2007 02:40 PM
Engine hood liner Mayoki General FSJ Tech 3 11-21-2005 09:50 AM
Engine final assembly questions JeepsAndGuns General FSJ Tech 29 08-02-2005 02:31 PM
Dead cylinder in new engine, and other problems??? Tino General FSJ Tech 10 12-03-2001 02:37 PM
