Old 08-22-2010, 01:48 PM
pensky2's Avatar
pensky2 pensky2 is offline
Question Electric cooling fans
I know it's been done before, but I want to install electric cooling fans in my 88 Wag. I have two doner fans from 07 Impalas. I have plenty of spare parts, I would like to find a schematic and parts list for this project.
Thanks in advance for your help!
Old 08-22-2010, 04:37 PM
smogdredd's Avatar
smogdredd smogdredd is offline
Why?
The stock clutch fan is quite adequate, I run the A/C in 100+ weather all the time with no problems.
'63 wagoneer '87 360 running gear except T case (207), warn hubs, 3.56 diffs and EFI Holley pro-jection using ford cfi throttle body Stock dist. with four wire HEI module.
'67 Scout 152cid w/EFI and turbo also My own a little help from Chrysler. I am a fabricator, I make stuff up!
facebookGGAutoCare
Old 08-22-2010, 04:52 PM
Are you sure that the Impala fans put out enough CFM to keep the 360 cool?? (I have never had an impala so I cannot help you there) but you definitely want to make sure it is within the range necessary.
I will try to find the old write up I had started (But was unfinished) on using and wiring up electric fans.
Found one of them (Now to find the schematics page I half-finished)
http://www.ifsja.org/forums/vb/showthread.php?t=54503
Found it. (The partially completed link is below)
http://www.ifsja.org/forums/vb/showthread.php?t=96202
Upgrades
2. Cs-144 Alt 10/1/11
(Wip)
1. TBI
2. New fuel tank
3. AW-4 Transmission
4. Aluminum condensor
5. Custom Gauge Panel
Electric Cooling Fans pensky2 General FSJ Tech 3 01-14-2004 02:19 PM
electric cooling fans.... crazyguy General FSJ Tech 2 06-25-2003 06:59 AM
Electric cooling fans crazyguy General FSJ Tech 3 11-23-2002 07:46 PM
electric cooling fans bigjim General FSJ Tech 19 06-04-2001 09:39 AM
Electric Cooling Fans fsj401 General FSJ Tech 9 02-23-2001 02:35 PM
