Old 05-09-2003, 10:12 AM
Narnian Narnian is offline
The Dana 60 in my J20 has been sour for the last four months. As best as I can tell the bearing that the drive shaft goes into is shot. I might be able to have a friend repair it, but I've noticed that unlike J20 Axles, Ford Dana 60 Axles can be found. Would a Dana 60 rear Axle from a Ford bolt up to my J20, or would it require a lot of modification? Is it the same width?
1981 Cherokee Chief Laredo: 360 w/Holley Fuel Injection, Edelbrock manifold, NP219, 3.31, 33\'s, no fuzzy dice (yet)<br />1987 J20: Stock except for the gaudy red Durabak all over the exterior<br />1990 Corvette that get\'s driven anytime I don\'t need to haul a load or go offroad and the temperature is over 32F.
Old 05-09-2003, 11:15 AM
80258WT 80258WT is offline
i have one in the rear of my jeep and it looks the same width of the front axle. The wms to wms is about 66"on the ford d60 and a full size front d44 is 65.5".
60\'s and 40\" mtr\'s
Old 05-09-2003, 11:36 AM
netbear netbear is offline
That's pretty close. Mt rear J20 D60FF
is 67.25 WMS-WMS. Only about 0.6" per side
difference.
I would try fixing your J-20 axle first though.
netbear
Dana 44 Front Axle Assembly with AMC 20 Rear Assembly bigD89 General FSJ Tech 9 10-30-2005 10:25 AM
dana axle BOM's fsjeep Off-Road FSJ Tech 14 07-29-2005 10:15 AM
Dana 44 axle shafts jjk General FSJ Tech 1 05-09-2003 11:26 AM
Dana 20 with q-trac rear axle Chero77 General FSJ Tech 7 04-22-2002 05:19 AM
Relatively Cheap Dana 60 Rear Axle For You Waggy Guys Rande General FSJ Tech 9 03-04-2002 03:01 AM
