I decided to finally start a thread on my upcoming rear dana 44 and np208 swap. I?ve been accumulating parts for these swaps slowly but I?m getting close to the actual installs (once I receive a few more parts). I wanted to see what ya?ll thought.
The rear D44 Swap is pretty straight forward?. I found a rear 44 out of an 88 (I think) GW at my local pick ur junk. It has the Trac-loc unit. My plan is to swap the trac-loc carrier up front, while loading up the open carrier from the front with a powertrax no-slip lunch box into the rear. At the same time I?ll be loading in new 3.73 gearing and upgrading the front hubs to warn locking hubs. Which will make for a cheep-o locked up front and rear.
Which brings me to the 208.. the 208 will be here by 5-2 and will be installed hopefully by the weekend after. I picked up a rear drive line from a Cherokee with a 208 from J&W. this is going to the shop to be cleaned up, painted and re-balanced on this coming Monday.
I plan on keeping the vacuum lines to the front disco axle also.
So what do you guys think?
(and yes I?ll try to take plenty of pics!!)
So far all that?s done is the rear 44 is painted. There?s a pic of that here: Differential Paint
