Old 03-18-2013, 08:52 AM
EL Grande Honcho EL Grande Honcho is offline
best towing option for boat with J10? Unlock hubs?
Hello:
I have a 1980 J10, manual tranny, etc.
I'd like to pull my boat with it. The load is about 1500 lbs. It is rather hilly where I live, but the boat launch is only 1-2 miles away.
What is the best way to pull it without causing too much wear on the clutch? Can I put in 4-wheel high, and not lock the hubs to and from the launch, and then lock the hubs when I pull in out of the water?
Any advice much appreciated!
Old 03-18-2013, 08:58 AM
Huh? Only use 2WD, except on the boat ramp.
Leave the hubs locked in until you are on the highway. Use low range if you need to to haul the boat up the ramp. Driving straight ahead, you won't get any bind-up in 4WD, and the low range will make towing the boat much easier. When you get to the top of the ramp, shift into 2WD.
Old 03-18-2013, 09:23 AM
About how fast without causing too much wear, can you drive pulling the boat in 2WD with hubs locked? 55 mph too fast?
Old 03-18-2013, 10:14 AM
serehill serehill is offline
Gone,Never Forgotten.
huh
When it's in 2WD it won't hurt anything. It will just turn the drive line in the front end. You could drive at any speed. Lock in the 4WD when you get to the ramp then unlock when you leave you could leave the hubs lock all the time as long as it isn't in 4WD for the drive home.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 03-18-2013, 02:20 PM
No damage is caused by locked hubs. Just a minor fuel consumption penalty
Old 03-18-2013, 02:24 PM
Talking
like 7 mpg instead of 8?
Towing with a J10 okjeep General FSJ Discussion 23 12-12-2008 08:53 AM
I drove my new J10 for 50 miles (long post) The PIG Smith General FSJ Discussion 46 04-17-2008 12:00 PM
FLAT TOWING AN 83 J10 FSJ-Earl General FSJ Tech 18 11-20-2007 06:02 AM
Towing with a J10 aerocorey General FSJ Discussion 20 07-08-2007 09:17 PM
Towing a rig off the trail w/a SWB J10? Reebles Off-Road FSJ Tech 29 06-09-2007 01:01 PM
