Old 04-08-2020, 07:48 AM
JohnB JohnB is offline
Supporting Cat Converter Air Tube
If I delete the air injection tubes, how do I support the Cat Converter air tube? I was thinking about re-using the banjo bolt and jbweld the holes closed using high temp jbweld putty. Would this work ok or how have others done it? Thanks for your help.
85 GW
Old 04-08-2020, 09:13 AM
Just remove the tube and cap/pinch off @ converter.
Makes no sense to keep it if deleting air pump junk.
Old 04-08-2020, 09:30 AM
I thought the cat needed the air so I was going to leave it.
85 GW
Old 04-08-2020, 11:04 AM
Most modern CATs do just fine without air injection.
Many universals come w/o a port for air.
Any that do come with a port it is usually already capped off.
If it was me I'd just yank it all
Old 04-08-2020, 12:15 PM
OK thanks for the advice. That will make it easier for sure.
85 GW
Old 04-08-2020, 12:17 PM
Except, my cat is not exactly modern-probably 15-20 years old at least. Does this change anything?
85 GW
Old 04-08-2020, 12:45 PM
If it's a 3-way cat(likely) it'll do just fine without air injection.
Major differences in a 1980-ish CAT vs 2000-ish+.
Original 80s OEM CATs used on these weren't great.
But nobody can really tell you what kind of shape your current one is in.
Also, the engine "tune" has a huge impact on lifespan
Some last 100-200k some last 50k and some only a few years.
Tube coming out of my air injection bolts rang-a-stang General FSJ Tech 10 03-06-2018 01:51 PM
so I need to add a catalytic conv to pass inspection, do I need an air tube? chadmjohn General FSJ Tech 4 04-29-2009 01:02 PM
hot air tube Frank Black General FSJ Tech 2 07-23-2008 07:30 AM
mpg and air tube removals Jeepeta General FSJ Tech 15 01-18-2006 08:27 AM
Oil pump losing prime / pick up tube air leak? Careful34 General FSJ Tech 2 08-10-2002 04:15 PM
