Old 04-03-2020, 01:14 PM
WinALDL which vehicle/engine to select?
I just ordered a red devil river aldl cable to try to figure out why my Howell 50 state TBI on my AMC 360 is running so poorly (1989 Grand Wagoneer, orig 360 engine). When I looked at the Winaldl software 4 or 5 months ago, I think that I had to select a vehicle and engine.
Which vehicle and engine do I select?
My Howell 50 state TBI has the 12 pin connector. Do I use the 10k resistor? What baud rate do I select?
Are there other selections to make to successfully download data?
Thanks.
Old 04-03-2020, 06:54 PM
Been sooo many years but pretty sure all you select is ecm type 1227747?
That is *if* that is the ecm you're running.
Old GM OBDI systems are 160baud
Comport = matching whatever aldl cable shows up as...
Never needed to use a 10k resistor on any TBI vehicle I've ever worked on.
Select Trac Front Axle Strength wijeeper Off-Road FSJ Tech 4 08-07-2012 04:54 AM
How to interpret log files WINALDL rmorit01 Fuel Injection 1 03-08-2011 06:57 PM
What does Select Track mean? djongeward General FSJ Discussion 20 03-30-2009 10:07 PM
Need someone with WinALDL Skills nosaJ General FSJ Tech 3 02-04-2009 05:16 PM
4x4 select switch m4 General FSJ Tech 0 08-23-2003 08:23 AM
