Old 01-17-2020, 07:27 PM
Jan Jan is offline
lockers 1972 wagoneer
Hi, after getting stuck a couple of times even with the rather soft off roading that I do with the old girl I would like to put lockers in my 1972 Wagoneer. Currently there are none. I am planning to keep her mostly stock otherwise.
I am planning to keep the stock axles (Dana 44 30 spline rear and Dana 30 27 spline closed knuckles front, both 3.73). Transfer case for this year is a Dana 20.
Will the typical lockers sold today for this axle type and spline count fit? I was thinking of manual lockers with electric actuators by ARB, Eaton or OX. I have read a lot about Does anybody have recommedations?
Thank you!
Jan
1987 GW (rebuilt 360, 0.03 over, Comp cam 256 XE cam, 9.0:1 pistons, Bulltear oil pump with nickel-plated timing cover and American perf. back oiling mod, MSD 6T)
Old 01-19-2020, 02:33 PM
For part-time selectable electric or air lockers you're probably limited to the big buck brands like ARB etc. For conventional lockers or LSD's call Randy's Ring and Pinion in Everette, WA. They'll know what's available. Even today D44's are still very commonly used diffs.
Old 01-25-2020, 07:55 PM
Mikel's Avatar
Mikel Mikel is offline
Not selectable, but I've had very good luck with Detroit Trutracs (Torsen geared type, no clutches to wear). They are completely invisible on the road and they engage smoothly when needed, without any driver input.
Not the best for a rockcrawler (will not actuate with a wheel in the air unless you tap the brakes), but for what I do, I'm very pleased with how they work. This winter I am yet to engage the front axle in my XJ.
1969 M715 6x6
1963 J300 Swivel frame
Old 01-26-2020, 11:42 AM
Be from Be's Avatar
Be from Be Be from Be is offline
I have the Truetrack in my front axle and I love it.
For the rear axle I plan to install e-locker.
See my video of the TruTrack engaging on 3:20 https://www.youtube.com/watch?v=WeqPQe7-RLA&t=227s
1978 Cherokee Chief
360 V8 Automatic
Quadra Trac w/ Mile Marker conversion
4" Skyjacker
Old 02-16-2020, 01:24 PM
Rod2's Avatar
Rod2 Rod2 is offline
Per my signature line, both my E-lockers came from Randys; the front is a closed knuckle 44, not a 30. There is a build number on your axle tube near the diff that you may use to search for info about availability.
Good luck, I love mine.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light, MileMarker 12,000 cradle mounted winch
Old 04-09-2020, 05:50 PM
Jan Jan is offline
Thank you very much for the answers! The project got delayed a bit for now, but I hope to get it done soon. Cheers Jan
1972 Wagoneer - 360 V8 - TH400 - Dana 20 tman008 Build Threads 5 02-11-2019 08:18 PM
1972 Wagoneer -- turn light switch marmoset General FSJ Tech 5 10-23-2006 10:30 PM
1972 Wagoneer -- Brake Booster a Pain to Install marmoset General FSJ Tech 11 06-20-2003 09:53 AM
SOA for 1972 Wagoneer? 72wag General FSJ Tech 2 01-29-2001 11:56 PM
