Old 02-15-2002, 01:55 PM
Shaggin' Wagon's Avatar
Shaggin' Wagon Shaggin' Wagon is offline
It's not a problem with the switch. Now what?
TIA
Keith
"I am just a simple caveman. Your strange ways frighten and confuse me."
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-15-2002, 02:20 PM
Michael's Avatar
Michael Michael is offline
Shaggin' That usually is an indicator that your brakes are worn. I believe it is for the rear brakes because thay cannot squel when worn out. I know the haynes manual states something like that...or at least I think it does. Mine did the same thing when my rear shoes were done...It went away when I redid them.
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 02-15-2002, 02:49 PM
That's weird. Just had the fronts done but not the rears, guy said they were fine. Is there an indicator for the fluid level?
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-18-2002, 01:10 PM
Lugnut Lugnut is offline
Your porportioning valve could be frozen in one direction or the other, grounding the "brake" light (completing the circuit). Or, could just be those rear brakes sending the fluid in the porport. valve too far in one direction because they are not properly adjusted (self-adjusters frozen). See if the rear brake adjusters are working properly. Possibly, the mechanic just pulled the drums, saw the shoes were in decent shape and assumed they were adjusted out to meet the drums without a lot of fluid being sent to the rears vs. the fronts.
\'83 J-20, \'78 CJ-7, \'83 Wag.(the Rag)parts donor.
Old 02-18-2002, 01:12 PM
Now, if I could just figure out why my dome lights are staying on all the time.....
Old 02-18-2002, 02:51 PM
arter's Avatar
arter arter is offline
There was a similar post not too long ago. Someone more knowledgeable than me (that's alot of people ) pointed out that the proportioning valve activates the light when it senses difference in pressure to front & rear brakes. My light was on yesterday, was leaking from a bleeder I didn't have tight enough.
M715NT; TBI 401, 400, 1339, 44's, 4.10's, ARB's, 35's, wag frame
Old 02-18-2002, 03:58 PM
Where is this infamous proportioning valve? Didn't see it in my manual.
Thanks
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-18-2002, 04:01 PM
Hey Lugnut, could it be a grounded door jamb switch? That'd be my first guess at your prob.
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-18-2002, 04:16 PM
arter's Avatar
The valve is on the left frame rail, below the master cylinder. The Chilton manual explains it a little better than the Haynes. First things I would check are sufficient fluid in the master cylinder and for leakage at the brakes and fittings.
Old 02-19-2002, 12:01 AM
OK, thanks Arter
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-19-2002, 04:38 AM
Veepster Veepster is offline
that light is also activated by the e-brake. the switch is down behind the e-brake foot lever
Peace.............BartG<br /><br />The Green Flash!<br /><br />360ci Custom 4v TBI<br />TH400, Parttime QT with low, TFI Upgrade<br />Edelbrock Performer Manifold,<br />4\" skyjacker susp & 3\" body lift<br />Rancho 9000\'s 33x12.50 BFG KO\'s <br />8\" American Racing Baja Rims<br />Thorley headers, 3\" exh, Dyno Max<br />Infiniti power leather seats<br />Billet shift knob by Millerluck<br />50%Luxury Car 50%Tractor<br /><a href=\"http://www.teamgodspeed.com\" target=\"_blank\">http://www.teamgodspeed.com</a>
Old 02-19-2002, 10:06 AM
Ooh, Veepster. Good suggestion. My technical mind went right past that grd. switch on the e. brake. That was just too easy.
And, Shag. -- you probably don't wanna get rambuncious and start tearing into that porportioning valve. They are quite expensive and I've never found kits available for them, and even if they were avail., the bore is prob. pitted from rust anyway and the kit wouldn't do any good. Some people, when they have trouble with this porpor. valve, just take it off and live without it. I'd rather not, if at all possible. This little diddy balances braking pressure front to rear on your vehicle.
Old 02-19-2002, 01:12 PM
You missed my first post , switch is fine. I may just kill the light and avoid all the troubleshooting.
Keith Brunson
91 Grand Wagoneer
05 Z71 Suburban
05 GMC Crew Cab
Various WMDs
Old 02-20-2002, 04:01 AM
also..you can get new proportioning valves for about $80...I replaced mine last year
parking brake switch/dome light question Steelhead General FSJ Tech 3 03-14-2005 03:58 AM
Brake dash light Traveler111 General FSJ Tech 4 06-30-2004 06:16 AM
One brake light works...... (update) Georgia Mike General FSJ Tech 8 03-31-2003 04:49 PM
Brake warning light won't go off RWC General FSJ Tech 4 09-02-2002 02:01 PM
Should my parking brake light be flashing? RudyC General FSJ Tech 1 01-20-2001 04:55 PM
