Old 01-21-2012, 11:38 PM
Bluesj's Avatar
Bluesj Bluesj is offline
Rear shoulder belt
I searched and saw lots of pics, but only one with the rear belt attached to the pillar instead of the roof..Any one do a write up on this?Any pros cons? to me it looks cleaner.
88 Grand Wagoneer
Old 01-21-2012, 11:56 PM
JollyRancher's Avatar
JollyRancher JollyRancher is offline
I looked into the door pillar option when I was researching this. Wagoneer World uses the pillar instead of using the factory ceiling mount. (http://wagoneerworld.com/optionsupgrades.php) The door pillar option does look cleaner, but in my opinion, it puts the belt too far forward. If you sit in the back seat and test out the two locations, then compare with the location of the belts for the front seats, you'll see what I mean. I have a kid still in a booster seat with a back on it, and the door pillar mount was not going to work for that. I also compared it to our old Volvo 240 wagon, and the rear ceiling mount puts it in pretty much the same location as the Volvo.
'91 Grand Wag
Colorado Red
RV Cam; Edelbrock 1406; HEI; Custom 4-row rad, 3" single pipe + Magnaflow 12289
Old 01-22-2012, 12:18 AM
FSJ Guy FSJ Guy is offline
The factory rear belt installation kit uses the "roof" mounted bolt hole instead of anything on the pillar area.
Jeep uses it, so it must be good enough, right?
If it didn't come up, see my sig link for my rear belt write-up.
Ethan Brady
www.bigscaryjeep.com
Old 01-22-2012, 04:25 PM
Bluesj's Avatar
FSJ guy, I did look at your write up and is probably the way Ill go..I would still like to hear from someone that post mounted it.And wouldn,t mind seeing the instructions from the dealer belts..
88 Grand Wagoneer
Old 01-22-2012, 07:18 PM
KyooMac's Avatar
KyooMac KyooMac is offline
http://www.ifsja.org/tech/interior/rearseatbelts.html
Old 01-22-2012, 08:14 PM
Bluesj's Avatar
Well I guess I just need to decide on new or used belts because I cant install what i don't have..thanks for the reply's..
88 Grand Wagoneer
Rear Window Switch Thread?? CJ5 General FSJ Tech 21 02-20-2013 08:08 PM
Problem with Brakes - No Pressure at Rear Brakes Kevin718 General FSJ Tech 4 01-20-2010 10:48 PM
Rear Dana 44 / NP208 Swap Jeepjohnny Off-Road FSJ Tech 24 06-04-2007 07:29 PM
Shoulder style belts for rear seat DieselSJ General FSJ Tech 16 04-23-2007 07:35 AM
rear seat belt install GW GWJoe General FSJ Tech 5 10-31-2005 10:17 PM
