Hey guys I'm new here, I just purchased an '88 Grand Wagoneer. Not my 1st 4X4 by any means but my first JEEP. Anyway it has 2.72 gears and a broken rear spring so I'm thinking lift! I've got a '77 chevy rolling chassis with a flat top knuckle D44 front and a 12 bolt rear w/3.73 gears. The Front spring spacing is exactly the same between the chevy and Jeep, it looks like any easy SPOA swap to me. Put a high steer arm on the pass. side and custom drag link and the right shocks and brake lines, possibly drive shaft and it's done in the front. In the rear move the spring perches, shocks, brake line, drive shaft, springs and blocks and the rear would be good to go.
So has anyone done this? I don't plan on serious wheeling so the 1/2tons and 3.73 gears would be fine. Am I over-simplifying this swap/lift?
I have a samurai that I completely built ever part of the suspension mounts and steering from scratch and did a 4.3/auto swap in, so I far from a newbie when it comes to fabrication work.
