Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Customer Corner: (Vendor product discussions)
Old 01-13-2013, 01:38 PM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
Available for Purchase: Drip-rail Molding - ABS/Mylar Polished Chrome
It's not perfect... But when there's nothing else... It ain't half-bad:
^ Left is the new ^ Middle is a GW connector ^ Right is the old GW plastic trim ^
Here's the link: http://www.outwatercatalogs.com/lg_d...channel%202412
1990 Grand Wagoneer:
1987 XJ Wagoneer Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
Member, FSJ Prissy Restoration Association (FJS-PRIS)
Old 01-13-2013, 06:05 PM
silvercert silvercert is offline
Nice... thanks for that.
Daniel
I have some good news and some bad news. The good news is that I always allow each student one free pass in my classes. The bad news is that you have now used yours for this class. Doug
Old 01-13-2013, 06:10 PM
Is it really 45 cents for 12 ft? Or is it 45 cents per foot?
Daniel
Old 01-15-2013, 09:48 PM
FSJ Guy FSJ Guy is offline
Umm.... I'm pretty sure it's 45 cents PER foot.
Thanks, Crist, for sharing your hard work!
Ethan Brady
www.bigscaryjeep.com
Old 04-09-2013, 08:23 AM
racegas racegas is offline
fitment
Crist,
I ordered some of this. When I tried it on my parts GW, to see how it fit, it did not 'click' on. Rather, I could move it horizontally away from the GW, with no resistance. Did you use double sided tape or some other adhesive?
For anyone considering it, they can't ship longer than 8', so you have to have them cut each stick down. 8' gives you about 3-4 inches extra on the horizontal section and 4' is more than enough for the A pillar. Shipping about doubles the cost. I got three sticks, so when I screw up one, I'd have a back up.
'Robert E Lee'
89 GW White w/Cordovan Interior(daughter's DD)
Old 04-09-2013, 08:42 AM
I had samples pieces of many different profiles... This was the best fit knowing that not all drip-rails are created equal on our GW's. It is/was hard to tell if the thin 3M tape was going to be necessary... Sounds like it may be.
Originally Posted by racegas
Crist,
Old 07-05-2016, 09:53 AM
mcboardman's Avatar
mcboardman mcboardman is offline
Noob!
Rain Gutter??
I know this thread is old but does anyone know if this stuff can be used for the rain gutter?? Thanks!
Mike
Old 07-05-2016, 10:37 AM
I used it and it didnt hold up to weather. It discolored within a year. If you want to see pics, let me know and I'll post a couple.
'Robert E Lee'
Old 07-05-2016, 10:58 AM
mcboardman's Avatar
Noob!
That stinks. Have you had better luck with anything else? Doesn't seem like there are any options out there other than finding some ss at the salvage yard. Thanks for the reply.
Old 07-05-2016, 01:28 PM
I had found a local guy this past spring who was willing to tool up to make a dozen sets from SS. They'd run about $150+/-. The quantity was based on using an entire sheet at one time. I didn't want to lay out the $, only to be stuck with 11 sets, so I proposed a pre-pay deal and asked who was interested. I had 7-8 guys offer to step up for a single set, but that wasn't enough, so I let it go. I'm still willing to pursue it if enough raise their hand, and more importantly, the $.
I just had an idea - I have a 90 Land Cruiser as well, which has SS molding as well. I just went to one of the primary sites for parts for it, to look at that molding. To begin with, the over the doors and rear side window is broken into two lengths, with a small clip overlapping the joint. Anyway, if a guy chose to, he could order what I guess would be 6 lengths of a straight section and use the clip to cover the joint in the middle. Going on the basis that three would cover the lengths on both sides - looks like that would run about $250. Or you could look for junked LC's. They are about as rare as junked GW's...
'Robert E Lee'
Old 07-05-2016, 01:43 PM
mcboardman's Avatar
Noob!
I'd definitely be in if your guy would make them for the GW and we could find enough folks to raise their hands (mine is up!). Might be worth putting it back out there to gauge interest?
Old 07-27-2016, 04:24 PM
408wij 408wij is offline
Noob!
Is there no u-channel stainless off the shelf in these (1/2 x 1/4) dimensions? Googling, I found some 1/2 x 1/2. This seems close in dimension to the mylar product: http://www.crlaurence.com/crlapps/sh...roductid=12135
Old 11-01-2016, 02:40 PM
JeffNode JeffNode is offline
Noob!
Looking for the elbow piece connector now. Any leads/suggestions?
Old 03-01-2017, 05:46 PM
Pasta_Man Pasta_Man is offline
I would be willing to pay for a set. Thanks.
Old 04-26-2017, 11:26 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
you can buy flat
chrome moulding
with 3m adhesive backing
on a roll
seems to be good quality
i got a roll off of ebay
it is same size as drip rail
and you can use adhesive
to make sure the corner metal peice stays.
dave in NC
Old 03-07-2018, 08:05 PM
Hi - how has the chrome moulding + adhesive backing done with the weather since you installed it?
Thanks. -Kevin
Old 11-08-2018, 10:35 AM
Question on the width for the chrome tape: should I get the 15mm or 20mm width?
thanks.
Old 11-09-2018, 06:31 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
Looks like I am going to need something in... black. Still doesn't seem like there are many good options out there
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 11-09-2018, 06:43 PM
JPSwapMohn's Avatar
50 CJ3A
Old 11-13-2018, 03:07 PM
SOLSAKS's Avatar
pasta man : the chrome plastic adhesive trim i have is only 11mm wide
and is the perfect size.
as far as durability
mine is always garaged and rarely driven
but this stuff should last approx 5 yrs minimum
and prob much longer even if left outside every day.
good luck
dave in NC
removing stainless drip rail trim centexjeeper General FSJ Tech 3 01-11-2013 03:03 PM
Drip Rail Molding Tchat General FSJ Tech 6 08-26-2011 01:46 PM
Where can I get new drip rail chrome? kevinp661 General FSJ Discussion 67 02-27-2011 09:15 PM
Help removing chrome drip rail trim F. Townsend General FSJ Tech 12 09-25-2010 05:52 PM
roof drip rail rust hogwagon General FSJ Tech 4 05-23-2004 01:58 PM
