Old 03-13-2017, 08:45 AM
conehead conehead is offline
FiTech distributor
I'm considering replacing the edelbrock proflow system with the FiTech EFI 4. I know I can use the electric fuel pump that came with the proflow but it also came with a mallory distributor and was wondering if I could use it too with the FiTech system. The distributor has three wires into it, RED, BLACK and one marked SHIELD. It doesn't have any timing advance mechanism on it, that's done by the programing the ECU. I know FiTech says it requires a two wire distributor but does that include the SHIELD wire? Thanks
Old 03-13-2017, 10:47 AM
I can't answer your question, but lemme ask, why do you want to ditch the proflo MPFI setup to go with a fancypants TBI?
Old 03-13-2017, 12:09 PM
x2
Old 03-13-2017, 12:43 PM
It's the first version of the pro-flow system. I have had it on the car for a number of years and have never been happy with it. I'll admit I'm not an expert on tuning fuel injection systems but there are hundreds of different tuning variable to deal with and I could not get the thing to stop pinging or running too rich or surging at idle. I gave up trying to fix the problems with edelbrock years ago and now that I'm in the process rebuilding the engine again I thought I might try a newer self learning system. I can buy an upgrade to the pro-flow 2 system but it's a ridiculously expensive, over 2 grand and from what I've read it isn't any better.
Old 03-13-2017, 05:34 PM
It has an option for a different than stock setup called TACH. That might be what you have.
I skipped that part because I have a stock distributor.
Here's PDF
http://fitechefi.com/fitech-uploads/...ideFinalV5.pdf
Old 03-13-2017, 06:23 PM
Abunchahicks Abunchahicks is offline
Noob!
You should only need the two wires going to the pickup. So the shield wire shouldn't be needed.
Old 03-18-2017, 05:18 PM
You can NOT use a timing control distr with the cheap 400HP system.
It is a fuel only system like the Howell EFI.
You need to run the 600hp system to have fuel and timing control like my GM based systems are.
Bill USN-1
Hamilton Fuel Injection
Old 03-18-2017, 09:00 PM
Noob!
The EFI 4 that he is considering is the 600hp unit.
I wish they made the 400hp with timing control.
Replacing stock distributor with HEI distributor xuno_gil General FSJ Tech 7 07-07-2011 10:38 PM
Jeep Small Cap EFI distributor Woodchomper General FSJ Tech 20 03-11-2008 01:53 PM
Installation procedure for OEM dizzy Sgt Rock General FSJ Tech 25 09-09-2006 06:45 PM
