Old 03-02-2016, 05:35 PM
nightglide nightglide is offline
Re: Fitech
Got my tbi unit......fuel,pump is bout a month out
Pace sends you the corvette filter and fittings so you just have to run return from filter to tank instead of from tbi to tank
Old 03-02-2016, 05:37 PM
Old 03-02-2016, 05:38 PM
Old 03-02-2016, 05:39 PM
Old 03-03-2016, 06:02 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
A thing of beauty is a joy forever.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 03-03-2016, 10:01 AM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
Originally Posted by nightglide
Did they give you the fittings that plug onto the filter/regulator as well? I thought that setup might be useful for a lot of tbi set ups til I read that the pressure is fixed at 58 psi which is pretty high for a gm type system. The FI system seems to be a completely proprietary set up. I am anxious to hear how it runs for you.
Old 03-04-2016, 07:07 AM
Wow! These guys seem really reasonable in their prices. So, what's the total system going to cost ya? I know the others are over $2K by the time you buy the fuel pump kit..
Old 03-04-2016, 07:33 AM
Yes...it also came with the fittings for the fuel filter and an fittings too.
So.......for the fitech, the corvette filter with all the fittings, the inline pump with 2 billet filters, all the an fittings for tbi to pump etc, 20 ft of fi rated -8 hose and 5 ft of -6 hose I'm in it for $1198.
I think the only extra I'm going to need is a 5/16 tube to change my return in my fuel sending unit, some wire to extend a few wires and maybe some clamps to hold fuel hose.
Not to bad I dont think for what I have.
Old 03-04-2016, 07:57 AM
And I'm pretty sure I can make a duraspark dist......which I have several......work for timing control for next to no $$$.
But that will be phase 2.....want to get it running on fuel only first.
Old 03-05-2016, 11:42 AM
Very Kool! I put in the Generic Howell TBI and it cost me a little over $1200. The Howells don't have timing or Learning and I had to stuff the ECM under the dash
Old 03-06-2016, 06:27 PM
All factory systems are self correcting and learning!
Howell chooses to only use half the system so you only get half the benefits of a good EFI system.
I do have upgrade kits for the those that bought the Howell system that upgrades it to be more like my system with fuel and timing control.
Bill USN-1
Hamilton Fuel Injection
Old 04-01-2016, 03:19 PM
80Limited 80Limited is offline
Any update on how the FiTech system is performing?
Old 04-02-2016, 09:06 AM
Still haven't installed it yet. Just got my fuel pump. Have a few little projects to do then I'm going to start on it.
Old 04-03-2016, 10:23 PM
skeletor's Avatar
skeletor skeletor is offline
nightglide, are you going to replace the stock 5/16" fuel tank outlet line in the fuel pickup to 3/8" as per the Fitech instructions? It's the one thing I'm not sure what I'm going to do...or if it's even really necessary...
I am waiting for my system to come in and I'm just going over stuff before I dive in...
-bryan
1984 j10 LWB
1977 Cherokee chief wide track(sold)
2004 LJ
Old 04-03-2016, 11:20 PM
Nope...on my truck the supply hose is already 3/8". The return is only 1/4" tho so I am changing that one to 5/16"
If yours is only 5/16" I would change it. They say best is 1/2"....at least 3/8" or else it will starve the fuel pump and wear the pump out prematurely
Old 04-03-2016, 11:24 PM
The one thing I'm debating is how far to extend the return. Factory is just a few inches into tank. I watched videos saying if it's above the fuel level it will airate the fuel in the tank and the pick up will pick up air and get uneven pressure. I think I will extend mine down with a bend so it's away from pick up.
Old 04-04-2016, 06:05 PM
skeletor's Avatar
How would you even change the tubes on the fuel pickup? Use a screw on bulkhead or weld it? For the return line, I was thinking about putting a return adapter like this:
http://www.summitracing.com/parts/mor-65385/overview/
But my j10 has what I can tell 1.5" hose, so that won't fit...
It would be so much easier if it could use the stock fuel and return lines.
-bryan
1984 j10 LWB
2004 LJ
Old 04-04-2016, 06:20 PM
Cut old tubes, drill holes bigger, solder new bent to match larger hard lines to plate.
Old 04-04-2016, 06:41 PM
Yup.....what baby wag said. Cut old return, drill it out, solder in new 5/16 return bent the way I want.
I thought bout that filler return thingy.....I have some steel tubing in my filler neck already that I could remove and and a tube but I think other way is easier. Ito not to hard to drop tank on a truck.
On a side note.......I did manage to get o2 sensor and temp sensor installed today......bout 5% there! Lol
FiTech? 80Limited Fuel Injection 21 03-12-2018 09:32 PM
