77 Cherokee 401, QT with low range 100k miles
My T-case had a loose chain and the resulting slip-stick noise. Had no leaks and the case functioned well - E-drive and low range work great. So I replaced the chain with a new BJ's chain - flawless installation! I didn't do anything else since I had zero leaks and it was working pretty good.
First test drive was on jack stands - everything works great! Took it for a drive and for the first time ever encountered no slip stick or binding. Drove 2 miles (1 mile in circles, both directions) then returned home to check fluid, thinking the chain side would need a topping off. Instead I found it overfilled by 1/4 cup. Hmm.
I Let the excess drain out and took it for a second drive. This one 4 miles with some parking lot figure 8's. Encountered a slip-stick type of noise in the turns. Took it home and this time drained more than 1/2 cup from the chain side. It seems obvious that fluid is going from the low range gearbox to the chain side.
Any ideas? Am I just overfilling the low range box? Initially I added 1.5 qts to chain side and 1 qt to the low range box.
Is the excess fluid on the chain side causing the poor driving symptoms?
