Old 02-19-2020, 05:19 PM
ZacharyH ZacharyH is offline
Holley 600 CFM.... good fit?
Got my motorcraft 4350 spread bore to square bore adapter. Would this be a good carburetor to swap in? Factory refurbished, 600 CFM, electric choke. I really like the aluminum finish on it. Will this work well the the AMC 360?
https://www.ebay.com/itm/Holley-0-80...P/283682784385
Old 02-20-2020, 06:38 PM
i would spend a little more and get something with changeable air bleeds.
like a quick fuel slayer VS,450 or 600.
you will find it runs better with a smaller air bleed on the main circuit,which increases the overlap of the idle and main circuits. something you can't change on an entry level holley.
Old 02-28-2020, 08:19 AM
Jeep Doctor
I ran a 600cfm Holley with that adapter on my stock '78 360, and it ran well, even off-road with some mods and lots of fine-tuning (accelerator-pump especially to eliminate the bog off the line; AMC 360's like a good shot).
If you can afford the model with the adjustable air-bleeds, that would be even more ideal for part-throttle performance (which is where most of your driving is done anyway) and overall economy.
Old 03-04-2020, 09:38 PM
Did you just adjust the spring tension or change the accelerator pump nozzle size? I am having a hesitation when i go from idle to WOT and the engine timing is perfect.
Old 03-05-2020, 01:03 PM
Jeep Doctor
I changed both the accelerator-pump cam on the throttle-arm, and went up in size on the shooters in the venturi.
Holley Truck Avenger.. Personal Experiances.. Dmntxn77 General FSJ Tech 30 05-17-2008 08:10 PM
Hooking up a Holley - Help. Cherokee01478 General FSJ Tech 8 01-09-2007 10:44 AM
Partial Holley TBI Parts Interchange List Spectre Fuel Injection 13 07-14-2006 12:36 PM
HOLLEY 2150 REMAN CARB - A GREAT CARB WINGO General FSJ Tech 4 11-25-2001 12:36 PM
Remanufactured Holley Headaches Dave _S General FSJ Tech 10 06-20-2001 08:20 AM
