Old 02-18-2020, 09:09 PM
Shep 762 Shep 762 is offline
Does any duraspark distributor fit our AMC engines?
Hey guys I'm trying to get my (new to me) 76 j20 going and it has the prestolite setup. I want to change it to the duraspark distributor with tfi upgrade. First I need to source a motorcraft distributor so before I go ordering one online, would it be possible that any of the piles and piles of 80s ford trucks in my local junkyards might have something I can use with maybe just a gear change? It would be so convenient to be able to just pluck one locally
Old 02-18-2020, 09:14 PM
78 WIDETRAC's Avatar
Shep
No ford distributors will work. at least on the AMC 360's anyway.
I think i have one. P.M. me a way to send you a pic.
Old 02-18-2020, 10:06 PM
bagusjeep bagusjeep is offline
Ifyou have the 258, i suggest a 1980 CJ7 dizzie. Right curve, straight fit
Old 02-18-2020, 10:28 PM
I have the 401. Actually lucked out on that, PO thought he had a 360 and sold it accordingly
Old 02-19-2020, 06:54 AM
bufurd's Avatar
bufurd bufurd is offline
My two cents, find a points distributer and put a Petronix or equivalent electronic conversion in it and be done. I'm running three vehicals with said setup and they've been flawless for many years..
Current fleet
07 JK Wife bought new...
Old 02-20-2020, 07:32 AM
I have three 401s with Skip White HEI. Another 401 has points dizzy. It will likely get an HEI. Skip White doesn't sell them anymore but there are other sources available. Price is reasonable and I like the single wire installation. I do keep a couple spare modules on hand but haven't needed to swap one out in several years.
Old 02-24-2020, 12:42 PM
I have a working duraspark module and the wiring left over from my build I would sell for cheap. I have a used original timing gear, too. They were on my 401 before I went to EFI.
You have to get an AMC dizzy. The Ford housings do not fit. Everything else is the same though (the pickup, cap, and rotor) except the vacuum can. I think you can get a cheap AMC dizzy from all the McParts stores, still though.
79 Cherokee Chief
Old 02-25-2020, 06:47 PM
UnkleMunky's Avatar
If you're looking to swap the distro out, I'd second the HEI option fulsizjeep mentioned. Have had a 258 with HEI and did a TFI upgrade on an 80 360. Just from comparing those two, I'd seriously consider HEI for any FSJ conversions (on the low end...MSD, etc. is another level altogether).
Michael (UnkleMunky)
'08 Dodge Grand Caravan
Some dogs, a few fountain pens...and too many sewing machines...
Our older engines and newer oil is not a good mix Kaiserjeeps General FSJ Tech 49 12-10-2018 08:11 AM
Duraspark to HEI Module- Another Writeup Walt General FSJ Tech 17 06-28-2011 01:48 AM
