  #1141
Old 02-14-2020, 01:17 PM
Full Size Jeeper's Avatar
1978 Wagoneer
Mods:
Old 02-14-2020, 01:20 PM
My son Jake came home for the weekend from LSU and helped me hang the tailgate.
1978 Wagoneer
Mods:
Old 02-14-2020, 01:21 PM
I was worried about the color matching, but it looks fine next to the quarter panel.
1978 Wagoneer
Mods:
Old 02-14-2020, 03:19 PM
So is that the rest of your painting? I mean, like cracking out the HVLP, careful masking, and base/clear? The rest is just little things here and there, right?
79 Cherokee Chief
Old 02-14-2020, 05:43 PM
Nope, the hood and front fenders are the wrong color, it is darker than the rest of the jeep. A gallon was mixed wrong at NAPA.
1978 Wagoneer
Mods:
Old 02-18-2020, 10:12 PM
I ordered a few things from BJ's Monday. The stainless lift bar for the tailgate glass is on back order. I'am off of work next week and was thinking I would be wrapping up the tailgate, but maybe not.
1978 Wagoneer
Mods:
Old 02-18-2020, 10:21 PM
Really taking my time and trying to make sure everything is where it needs to be. Serehill did a great job figuring out how to fit that stuff in the gate. When I started fitting things, I said to myself, no way it was going to fit. It is very tight but I know it fits.
1978 Wagoneer
Mods:
Old 02-18-2020, 10:27 PM
I have the safety switch wired in and I was able to pull the harness through that small hole at the bottom of the tailgate. Also have the wires for the license plate light in place, but not to a power source yet.
1978 Wagoneer
Mods:
Old 02-19-2020, 12:13 PM
chubbinius's Avatar
Wow, that is one clean and shiny looking tailgate. Very nice!
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 02-19-2020, 02:27 PM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
I want to see where you mount the plate, I never could figure out how to mount it in there, I talked to Rick several times, and just couldn't figure it out. I just have mine lying in there unsecured, but it keeps getting wet and blowing fuses...
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 02-20-2020, 10:55 PM
bwwhaler, here is where I mounted mine. Two things, I have not tried it with the glass in place yet, but the regulator does clear it when going up and down. Also the harness I have does no have that bulky remote unit that I have seen in some of the upgraded harnesses.
1978 Wagoneer
Mods:
Old 02-21-2020, 10:04 AM
bwwhaler's Avatar
Thanks, that's where I figured he was talking about, I will mount mine there when I get back in there, which will be soon... will probably solve my fuse problem also. I don't have the optional remote,(didn't have the money at the time), so mine is exactly like yours....
Old 02-21-2020, 12:26 PM
The relays on mine were wired wrong. 87A on the relay should be left disconnected. For some reason, the harness had ground wires running to both relays at 87A. My father-in-law helped me trace down the problem. It was trying to put 12 volts to both sides of the motor at the same time. With 87A disconnected, I goes up and down really quick. Can't wait to get it finished! Feels good to have a win every now in then!!!
1978 Wagoneer
Mods:
Old 02-21-2020, 12:28 PM
The white wire with the black stripe in the middle was the problem.
1978 Wagoneer
Mods:
Old 02-21-2020, 12:29 PM
Pulled those two wires, and we are now in business!
1978 Wagoneer
Mods:
Old 02-21-2020, 01:56 PM
SJTD SJTD is offline
Pics in last two posts aren't showing for me. Seeing the big minus.
Is it just me?
Sic friatur crustulum
Old 02-22-2020, 12:00 AM
I see pictures.
79 Cherokee Chief
Old 02-22-2020, 09:15 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
I see photos too.
Old 02-22-2020, 09:57 AM
Thanks, fixed them.
1978 Wagoneer
Mods:
Old 02-24-2020, 07:52 PM
I've been working to get this tailgate wiring harness in and it has kicked my A$$. I have tried to get the relays and junction block to fit and still allow the glass to go all the way down and I can't figure it out. I have given up and changed direction. I moved the relays and junction block under the jeep and made 3 new longer harnesses for the motor, safety switch, and the key switch. I still need to figure out how I'am going to keep it dry. Just to be clear, I'am not saying it can't be done in the tailgate, but for the life of me, I couldn't make it work. I will post some pics when I get it all wrapped up.
1978 Wagoneer
Mods:
FrankenJeep (Turbo Wagoneer) build thread Ghinmi Street & Performance 230 10-04-2015 09:11 PM
How tall for a daily driver / mild off road Wagoneer lorenmjones General FSJ Discussion 18 09-11-2014 05:57 PM
Build thread - 3x Grand Wagoneer 89/90/91 sportsidedan General FSJ Discussion 22 09-03-2013 12:11 PM
