Old 01-28-2020, 09:02 PM
Tripwire's Avatar
Tripwire Tripwire is offline
good 20-250 inch pound 3/8 torque wrench recommendation?
looking for one thats reasonably accurate and under 100 bucks - any tips? it has to be proven/ tested by you to be quality....no amazon reviews please
steve
Abort? Retry? Ignore? >
Old 01-28-2020, 10:14 PM
asphaltrockdweller's Avatar
I bought one from Summit racing that is 3/8" 25-250 ftlbs that has done really well for me.
https://www.summitracing.com/parts/WMR-M197
I was doing some work on my XJ, and needed one really fast, not to mentioned I had an order I was putting together anyways with them at the time. They are really fast on shipping too.
Old 01-29-2020, 11:53 AM
Kaiserjeeps's Avatar
I bought my last one from Summit also. You can't beat their return policy or their pretty consistent quality. Mine was 4 feet long and I think topped out at 350 FT/lbs. I needed it for putting together an old dozer.
Be sure to remember to unwind the thimble and release all the tension if it is a click type before storing it back in the drawer. That keeps them accurate longer.
So a second vote for Summit.
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
1970 and 71 project J trucks
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's and a 7
Old 01-29-2020, 06:05 PM
Tripwire's Avatar
thanks guys - but i need INCH pound wrench not FT pound
Old 01-29-2020, 07:33 PM
Dont you just convert it and use a LB wrench?
I think I read that in the chilton book or somewhere. Cant recall if its 12:1 or 16:1
Old 01-30-2020, 10:49 AM
I got that Trip. Summit sells those to. I figured you would go look. My main point was how Summit is a pretty good place to spend your money.
EDIT: Here... https://www.summitracing.com/parts/wmr-m197/overview/ It IS inch pounds. And 3/8 drive. I think asphaltrockdweller meant to say inch pounds. Perfect....
Am I done yet?
1969 1414X Wag,
1983 FJ60 wagon
CJ-5's and a 7
Old 01-31-2020, 01:00 AM
The one I have experience with that I listed from Summit is inch pounds.
Old 01-31-2020, 09:33 AM
You get what you pay for, it will work but really how accurate will it be? I use my snap on( professional mechanic for 30 years) and yes it was expensive but it is accurate even today after many years.
Old 01-31-2020, 11:07 AM
steve
Do you want dial, click or beam? I have the 1/4" drive Neiko beam type wrench, which I bought to set preload on steering gears. I'd think any beam-type wrench would be fine for something like that. I have 3/8" clickers, but nothing with inch-pound range.
You could step up to one of the mid-range brands like GearWrench - https://www.amazon.com/GearWrench-29..._encoding=UTF8 - Design and construction of these is awfully simple, and I expect the cheaper brands would work just as well.
Old 01-31-2020, 07:01 PM
Tripwire's Avatar
Thanks, for the replies I have a friend who owns a BMW racing shop who will lend me one for.......changing the spark plugs on my Caddy SRX which requires removing the Intake Manifold
since I am going in that deep I'm changing all six coil packs as well - nothing like a 500 dollar spark plug change
Old 02-01-2020, 10:58 AM
So is this not the right way? Converting inches to pounds?
Old 02-01-2020, 11:24 AM
Tripwire's Avatar
yes its math and works sometimes - but however if you need to tighten something to say 120 inch pounds your probably have a hard time finding a accurate Ft Lb torque wrench that goes down to 10 Ft pounds
Old 02-01-2020, 08:08 PM
Okay great! I just wanted to make sure and verify it. Sometimes I do things that may be dangerous or wrong because I donT have as much experience and quite understand them. I just learned there was a such thing last year when I looked up the torque in the chiltons book for some(I cant even remember what for) bolts and it was so low.Kinda freaked me out because I thought I might have to go buy another tool or something but when I googled it it said to convert it.
FSJ Leaf Spring Sizes (length, width and bushings) 86comanche Suspension and Steering 5 09-08-2011 05:26 AM
Ring gear bolt tourque j20brett Off-Road FSJ Tech 24 03-10-2009 09:43 AM
Dacco Torque Converter any good? Joe Guilbeau General FSJ Tech 11 02-12-2009 11:43 AM
torque wrench calibration skid2964 General FSJ Tech 5 04-15-2004 05:57 AM
727 Auto inch/lb torque wrench Erix Jeep General FSJ Tech 10 08-28-2001 02:12 AM
