Old 03-20-2020, 02:05 PM
Lister Lister is offline
Chrysler 440 swap?
I've been keeping an eye out for a V8 engine/trans combo to swap out my non-running 258/4 speed (82 Laredo Widetrack). Wanted keep it simple with an older carb setup (preferrable 360 or 401, but nothing near me yet). A 1975 Crysler 440 from a New Yorker came up close to me for $500. Comes with a 727.
https://www.facebook.com/marketplace...7066686077838/
I know nothing about these. Good option? Would a big block fit ok? Can the tailhousing of the 727 be changed to accept a tcase?
81 Laredo I6
17 Crosstrek
Old 03-20-2020, 03:48 PM
yes and yes.
Old 03-20-2020, 05:56 PM
Mikel's Avatar
Mikel Mikel is offline
I have no idea if any of those things fit. But do it
1969 M715 6x6
1963 J300 Swivel frame
Old 03-21-2020, 01:29 PM
Bought it. Compression tested good. Stoked!
81 Laredo I6
17 Crosstrek
Old 03-21-2020, 11:48 PM
Oh man!!! AWESOME! Get some pictures and a story posted!!! That sounds AMAZING!!!!
79 Cherokee Chief
Old 03-22-2020, 08:06 AM
Rusty76 Rusty76 is offline
Very cool good job
Old 03-22-2020, 08:28 AM
Yes regarding the 727. Have a re-builder add the tail assembly from your Jeep 727 to the Dodge 727. Theres another member here that is running a 440 in his FSJ. Not sure the name but search 440 under Topics
Old 03-22-2020, 08:56 AM
http://www.440source.com/strokerkits.htm
543 cubes outta do it.
Old 03-23-2020, 12:36 PM
I've been looking into this. have to source a Jeep 727 for the swap as I have the 4 speed in mine.
I will have a look for the other 440. Thanks. It will be a while before I get to any sort of install, but will definitely post any updates.
81 Laredo I6
17 Crosstrek
Old 03-27-2020, 08:16 PM
Run good oil in the 440 to save your bearings. That was their biggest issue I recall. Do NOT run an orange oil filter. I think BJs sells the motor mount kit.
I would update the 727 a bit with parts from a V10/Cummins version since it has an improved front pump and torque converter. Big block 727 was used with the Nissan SD33T 6 cyl diesel with an adapter ring in the Scouts. It looks a lot like the small block 727, BUT identified from each other by the small bolts in the splash pan. Starter is driver’s side on both but the big block bell pattern has 3 small (1/4”? 5/16”?) bolts and small block has 4.
The torque converter has the ring gear on the Mopar motor since 1965. There is 2 different crankshafts on the 440s as well. Truck and Motorhome ones often have the 8 bolt crank flange (heavy duty). I would look at doing a SEFI flexplate while it’s apart and replacing the 727 front seal and bushing at the minimum. STP oil treatment is your 727s friend. If you are gentle on the 229 in AWD it will live awhile. It’s too bad they never made an O/D Mopar bigblock patterned 727.
Old 03-27-2020, 08:19 PM
I would consider a 4.0L or even stroker 6 swap since it’s a bolt in deal.
Old 04-01-2020, 12:08 PM
Herk's Avatar
Herk Herk is offline
The good thing about Torqueflites is that hey tend to be the same except for the bell housing bolt face. If your Jeep has a 727 now, you need the mainshaft and rear housing to convert a 2WD 727-B. OR you could try to find a 4WD big block transmission.
Since you have to completely disassemble the transmission, consider upgrading the internals. Jeep specified a pretty light duty front clutch pack, so you may be better off using the front drum form the Mopar unit.
Old 04-01-2020, 06:02 PM
Mikel's Avatar
Since your truck came with a 258, it probably has relatively low gears. May want to look into some OD trans that will bolt to your 440...
1969 M715 6x6
Old 04-01-2020, 10:34 PM
No way! Go buy some skinny pizza cutter tires and have a burn out machine!!!
79 Cherokee Chief
Chevy Swap, I know its been done a lot, but... GoldenEagleJ10 General FSJ Tech 2 08-05-2010 02:18 AM
Steering colum swap question derf General FSJ Tech 15 02-04-2010 09:01 AM
isuzu axle swap flatlander58 General FSJ Tech 9 12-15-2009 10:28 PM
my experiences with a 14bolt swap into a cheif malodin Off-Road FSJ Tech 7 01-31-2007 10:54 PM
Turning Radius, Pitman arm? Steering swap. Louiseven General FSJ Tech 5 11-30-2006 12:25 PM
