Old 12-08-2015, 05:01 AM
Driftwood's Avatar
Hi-Lift jack mounting
Has anyone mounted a Hi-Lift jack to their FSJ?
I'd like to see pics of the various mounting locations.
Old 12-10-2015, 01:01 PM
Nikkormat Nikkormat is offline
Me too
Yeah just how do you all carry that big heavy thing around?
Old 12-10-2015, 01:29 PM
Not on a fsj but have on CJ's and a few trucks. Mount 2 L-brackets to the bumper. Bolt the base to one and the frame near the upper end to the other.
Old 12-10-2015, 04:22 PM
firedog firedog is offline
I have. I'll get a pic as soon as I'm done welding up and routing some exhaust pipe. Basically, I used the hood style mounts just inside the rear door on the floor. We're in Moab jeeping every year at least once for 2 weeks, so I don't like going places there without it. Guarentee I do more bouncing and moving around than 99% of GW's, so if mine didn't move at all there, I'm guess it wouldn't on yours either. stays out of the way there and is easy to access when needed.
Send pics in a few when it's off the rack. taking a coffee break.
1990 Grand Waggy / Howell TBI AMC 360 / DUI Performance distributor / BJ's 6" lift ' / 35" Kevlar MTR's / 4.56 gearing / E2 lockers front and rear / Sway bar disconnects / Hydroboost brake system / HD UJoint rag-joint eliminating steering shaft / and various other real nice goodies
Old 12-10-2015, 08:25 PM
Fort Wayne Frank's Avatar
Fort Wayne Frank Fort Wayne Frank is offline
Noob!
On my J10 I just used hardware available from the same company and mounted it to the side rail inside the truck bed (using some 2x4 to provide adequate space). Since I have since removed the jack (leaving the mounts in place), there is no point in uploading a photo.
Old 12-11-2015, 06:58 AM
efarrell's Avatar
efarrell efarrell is offline
Noob!
hood mount
I used to have a JK and had a River Raider hood mount. Building up a GW now and wished there was a similar mount available, but haven't found anything yet.
Old 12-12-2015, 08:24 PM
Tripwire's Avatar
Tripwire Tripwire is offline
If I had to have one - I would mount it on the roof rack frame, or under the rear passenger seat, with a bit of work you could put it in the dead spaces in the rear cargo area sides
Abort? Retry? Ignore? >
Old 12-14-2015, 12:11 AM
79jeep360's Avatar
79jeep360 79jeep360 is offline
I made a bracket for my lights and off of that bracket I made small brackets for the jack, Ian sure you could do something like that without the light bracket
1979 Cherokee 4 door 360 4 barrel intake and carb
3in rough country lift 33x12.50r15 tires
Transmission- Warner T-15A 3-sp
Transfer Case- Spicer 20
Axles- Dana 44 3.54 gears F&R
1973 cj5 d30 front d44 rear 3.73 gears
232 inline 6
Old 12-24-2015, 05:10 PM
Driftwood's Avatar
Now, I like this!!! Courtesy of Logans Run....
Old 09-03-2019, 08:41 PM
Driftwood's Avatar
I bought this 4 ft Hi-Lift Jack today at a junk store. $20 bucks!
Need to mount it somewhere.
Old 09-05-2019, 07:27 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
well, since your red wagoneer is one of my favorites on the forum
hope you find a good spot.
awesome heavy duty jack
and a good find at an even better price !
dave in NC
Old 09-11-2019, 10:29 PM
bagusjeep bagusjeep is offline
Never had it mounted on my J20, enough room in the back just to throw it in. I had it on my CJ, base resting on bumper with bolt and lock clamp from Hilift holding it on to wheel carrier frame. Broke off after a few years of driving, they are real heavy and need a really strong mount. only used it a few times and it was more trouble than it was worth.
Suspension Lift ?'s...HELP!!!!! 86j10 General FSJ Discussion 23 12-15-2009 03:33 PM
High Lift Jack Mount etjeep Off-Road FSJ Tech 10 07-11-2007 08:43 PM
Variable hight (2" or 4" lift) shackle flip? DanHS General FSJ Tech 2 05-03-2007 12:50 PM
rusty's lift install write up kreb General FSJ Tech 6 06-29-2005 12:20 PM
1970 Wagoneer Lift - Jack Slip Fix Tad General FSJ Tech 6 02-03-2002 10:52 PM
