Tonight I was trying to determine if the rear differential on my "new" '63 J-200 (vin # 2406B 10571) was a D53 or D44 and it looks like I need help on a few things. I found lots of numbers on the rear differential but not the correct ones, however, it looks like it is a little larger than the front differential. While both have 10 bolt covers, the front cover is a little "pointed" on the top and bottom while the rear cover is flat on the top and bottom. Also, the rear diff has 4 gussets between the housing and axle tube while the front has three.
Of more imediate concern, the tag on the rear diff says 45:11 4.09 while the front one says 47:11 4.427. I think that I read that the 4.27 diff is standard for this truck so it appears that the rear axle was swapped out - plus the rear shocks are unbolted. Since the pinion gears are the same, can I find a 45 tooth ring gear for the front axle (a D44 I think) and just replace the 47 tooth gear?
Thanks.
Kevin
Thanks.
Kevin
