Old 12-18-2010, 01:52 PM
stokes.greg's Avatar
stokes.greg stokes.greg is offline
Back glass stuck down Need help
My Tailgate window is stuck down, its cold and my new exhaust is straight out the back. How can i get it up enough to replace it with my new teamwagoneer.com manual crank.
1988 Grand Wagoneer
3 inch body lift
Jasper 360 auto
Needs: winch bumper, razor grill, tire carrier and 33x10.5 BFG's on 5 slot wheels
2006 Harley Davidson FXSTSI Springer
Old 12-18-2010, 01:59 PM
Karvin Karvin is offline
Guessing since you are replacing it with a manual kit that it is electric? You MIGHT be able, if you can access the gear mechanism, to take the window carrier off the scissor assembly. Then you can just pull the window to the upright position. Of course it won't stay there however, so not sure what you can do after that.
Perhaps you can disconnect it from the scissor assembly and then pull the scissors to the upright position and then reattach it to the window carrier? That wouldn't work on mine however, window must be down to close the rear gate. Not sure how it is on other models.
1977 Cherokee Chief Levi's Edition: specs to follow investigation.
2002 TJ Wrangler "APEX" Edition 4.7 Stroker, 4" RC Lift, 33" Toyo MT's, SmittyBuilt Front Bumper. More to follow
1974 J-10 258, T18/D20, D44 F/R 4.10 gears and LSD (No... not that type of LSD)
Old 12-18-2010, 04:22 PM
mdill's Avatar
mdill mdill is offline
Reach in pop the clips off the regulator arms at the bottom of the window, push the arms down to disengage the track pull the window out of the tailgate.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 12-18-2010, 04:48 PM
Rocket Dog Rocket Dog is offline
second the last post..... I had the same problem. you have to reach in with a long screw driver or some long niedle nose and take the c-clips off, then push the assembly down with the screw drvier as a prybar on the track, no the glass.
once both arms are off, pull the window out and support it..... carefull when you take the electric motorr off, its under a lot of tension and well try to take some of your fingers off.....
Old 12-18-2010, 05:19 PM
Thank guys, I removed the clips and pulled the glass out. I'm taking the entire unit out and putting a crank in to fix all motor problems.
1988 Grand Wagoneer
3 inch body lift
Jasper 360 auto
stuck in 4x4...HELP ITLBOK333 General FSJ Tech 4 10-26-2010 03:29 PM
Weird back firing issue KaiserMan General FSJ Tech 9 08-26-2010 01:22 PM
Back Seat - Baby Seats? Tanker (MWJT) General FSJ Discussion 20 12-06-2007 01:55 PM
Is your T-176 stuck in gear? Fix it free! grand_wag_85 General FSJ Discussion 3 06-21-2007 04:30 PM
Tailgate glass 84_grand wag General FSJ Tech 6 07-11-2001 01:40 AM
