Old 11-26-2010, 10:02 PM
Rocket Dog Rocket Dog is offline
bolt size for hanging motor on engin stand
I need to get some diffrent bolts for my motor in order to bolt it up to the engin stand. For some reason the set I had are too big.
anyone know the thred size of them?
thanks,
RD
Old 11-26-2010, 10:21 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
3/8 and 7/16 course
3/8 course thread. The bottom 2(alignment dowels) are 7/16 course, IIRC.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-26-2010, 10:23 PM
REDONE's Avatar
REDONE REDONE is offline
They're right above. Mine were boogered so I drilled tapped to 1/2x13.
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 11-26-2010, 11:50 PM
Elliott's Avatar
Cowboy Up
Jinx
Old 11-27-2010, 09:48 AM
Originally Posted by Elliott
Jinx
LOL, you got me...
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-27-2010, 03:55 PM
thanks going to the depo right now since the kid are done with the saturday moring sports.
Old 11-28-2010, 10:40 PM
I couldn't get the larger bolts at the depo so I'm using the 4 of the 3/8 right now since the heads are off.
Old 11-29-2010, 10:00 AM
64 wagoneer's Avatar
64 wagoneer 64 wagoneer is offline
Not to hijack this thread, but I plan to use a engine hoist to remove a motor. Do you use the same size bolts and install in the same holes that you would for the engine stand? Thanks in advance.
Ron
1964 Wagoneer 4 door (project)
http://i157.photobucket.com/albums/t...v/HPIM1527.jpg
1965 Belair station wagon (project)
http://i157.photobucket.com/albums/t...uv/65chevy.jpg
Old 11-29-2010, 10:28 AM
J20 project's Avatar
Kinda hard to use them on the back of the block while lifting the motor. Use a chain and a couple of the bolts on top of the motor. Remove opposite, angled front and back of the engine. Remove those bolts, install longer ones that go through the chain(18-24ins) and pull the motor up. Or, use 2 front and 2 rear and 2 chains. Follow me?
J20
BP Drivetrain...........
775-537-7918
Old 12-05-2010, 01:01 PM
I plan to use a intake braket or one of thoese engien host things that they sell at horbor freight with the tabs and has the ablility to pitch the motor
Old 12-05-2010, 01:26 PM
The PIG Smith's Avatar
King Browless
There has been some discussion in the past of an engine plate that bolts to the intake (where the carb site).
There more than a few that think the smaller bolts that hold the carb to the intake and bolts holes in that area are not strong enough to safely hold an engine.
Also, these folks claim that the yanking and jerking of an engine as sometimes one needs to do to get it free, it really bad news for an intake.
Picture courteous of Summit Racing
I have never used one (because I never owned to use)
I've used larger bolts in the ends of the heads.
One on the back drivers side and one on the passenger side front.
Why there? ...because I can get the holes easy.
These are larger bolts, 1/2, 9/16, maybe 5/8...I do not remember.
I used grade 8 hardware
I then use lift brackets that came with my engine hoist weight redistribution sling.
I bolt these brackets to the heads.
I had to get longer chains.
Whatever you do and no matter how you do it, be safe!
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
229 transfer case filler bolt size? wanderson General FSJ Tech 3 09-27-2010 06:43 PM
Low range lever bolt size v10sport General FSJ Tech 0 09-15-2010 08:12 PM
Bolt size needed for bed mount 1981 J20 HOOT General FSJ Tech 8 08-05-2010 11:41 AM
Flexplate bolt size?? Puritan21 General FSJ Discussion 8 04-26-2010 09:36 AM
Transfer case fill plug bolt size ItchyRichy General FSJ Tech 1 07-21-2001 08:32 AM
