I was wondering if any year wagoneer body will bolt right on to my 76 cherokee frame?
body swap ?
I think Wag/Chero body mount styles changed a little between Kaiser/AMC but were essentially the same location. I do not recall any differences between AMC/ChryCo rigs except that the trucks do not mate exactly to the Wag/Cheros in the cab location mounts.
Should be very doable for Alex.
There are a good deal of electrical differences between '78 and '87, not sure what that would mean for Doug (I know that's not body mounts but just something that will come into play in the swap).2000 Infinity QX4, 3.3L, MPFI, 4 speed auto, 2 speed Nissan tcase, Unibody, IFS front, 4 link rear solid axle with 255-70/16s
There may be a small issue w the transmission hump on the passenger side because of the TH400, TF727 differences, but a 1" or 1/2" body lift can fix it.
some early years have an extra frame mounting post in the mid section driver to passenger area, that was omitted after 77-78
Same issue when mounting newer passenger seat, you need to keep the brackets from the receiving vehicle.Michel
85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
