I have many questions regarding the I6 to V8 swap, but the primary one is this: do any of you know of a write-up or thread that has "complete" information for the swap?
I searched ifsja through google and every thread that I have found has bits of info here and there (as well as many replies that read "search the forums there is plenty of info on this").
I can't seem to locate a write-up or near-comprehensive swap thread. Anyone have a direct link to one of these threads that so many have referenced?
OR, if anyone would like to add in their knowledge here, to the best of my ability I have found this info:
-258 motor mounts need to be cut off and replaced with V8 mounts
-V8 radiator/core support panel will need to be swapped in
-transmission crossmember will need to move, but there should be pre-drilled holes for it
-driveshafts may need to be lengthened/shortened
-wiring harness may need to be altered, or swapped
Is that really all there is to this?
For reference, I am going to be swapping OUT the 258/727/208 from my 82 J-10 and swapping IN a 360/T18/208 from an 83 J-20. Both trucks are complete in my yard right now.
Thank you!
Thank you!
