Please help, my DD is dead. 88 gw with amc 360 sputtered and sputtered on the way home after it got to operating temp. 105 degrees today here in s.e. MM. Then it stalled, a few times and died completely. Will not restart now. I have plenty of gas... in the jeep. Please throw ideas this way. Vapor lock? Maybe... how to cure?
stalled, died, will not restart
my first thought would be
Originally posted by newwagwheelerPlease help, my DD is dead. 88 gw with amc 360 sputtered and sputtered on the way home after it got to operating temp. 105 degrees today here in s.e. MM. Then it stalled, a few times and died completely. Will not restart now. I have plenty of gas... in the jeep. Please throw ideas this way. Vapor lock? Maybe... how to cure?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
I am subscribing to this thread. I want to see what others post. I have gotten a lot of advice about an electric fuel pump. And, I have also been told that the electric fuel pump will just mask over the real issue. Just wanting to read more...'83 Scrambler (CJ-8) / 258 / T-5 / D-300 / DANA 30-AMC20 (3.31)
simple
Originally posted by twmattoxI am subscribing to this thread. I want to see what others post. I have gotten a lot of advice about an electric fuel pump. And, I have also been told that the electric fuel pump will just mask over the real issue. Just wanting to read more...
Aways possible it's vapor lock or other unperfected issues. A little information causes massive speculation. Assuming he has gas at the carb then you could elimnate that issue.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
definitely sounds like a fuel pump. You can get a new Carter pump from rockauto for 23 bucks.
Actually just added one to my order, feel like thats could be the next thing to fail...Last edited by austinaubinoe; 07-26-2011, 11:07 PM.Austin
Originally posted by rustywagoneers_comi am not an addict, i can stop anytime.
vapor lock
Originally posted by newwagwheelerWell the fuel filter was too hot to touch... like burned my hand hot. Put a bit of starting fluid in the carb and she started right up. Moved the filter away from the manifold, so we will see how it works tomorrow.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
I have had a couple wagoneers that vapor locked in the summer no matter what I replaced/did to them. I used to have a red '91 that vapor locked when it was over 90 degrees no matter what. I basically replaced everything and it couldn't be cured. I never put on an electric fuel pump though. The '89 I am driving now never vapor locks. I remember as a kid in 1991 when my mom had a brand new 1991 Grand Wagoneer that it vapor locked on a road trip to Santa Fe in 90ish degree heat on the side of the highway Good times2013 Dodge Durango R/T AWD-Hers
2000 Dodge Ram 2500 4x4 Cummins-D.D.
1989 Jeep Grand Wagoneer 6" BJ's lift and 33's
1981 Jeep Wagoneer Limited
1981 Jeep J-10 Laredo new 401 6" BJs on the way
1980 Jeep Cherokee Laredo 401
1980 Jeep CJ-5 Laredo 304
I know that my wife's cj likes to vapor lock.Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken
Gunner. Sabot. Sniper. Is not an appropriate use of ammunition.
Noli me tangere! - Old Guard 3rd US INF.
most of them
Originally posted by bull4377I have had a couple wagoneers that vapor locked in the summer no matter what I replaced/did to them. I used to have a red '91 that vapor locked when it was over 90 degrees no matter what. I basically replaced everything and it couldn't be cured. I never put on an electric fuel pump though. The '89 I am driving now never vapor locks. I remember as a kid in 1991 when my mom had a brand new 1991 Grand Wagoneer that it vapor locked on a road trip to Santa Fe in 90ish degree heat on the side of the highway Good times
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
fuel line insulation
Originally posted by serehill.... If you re route the lines or insulate them it will help stop.Jeepasaurus (Wagonus Grandi quadropedus)
well you could sleeve rubber hose over them.
Originally posted by Rich88Curious what the best insulation method might be. Is there a 5/16 or 3/8 seamed equivalent to the stuff used for copper water pipes?
I'VE NEVER SEEN THIS USED
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Originally posted by newwagwheelerBy the way, this problem has just recently developed. I have not made any changes since last summer and it did just fine in the extreme heat.
Then that's reliable evidence you probably don't have vapor lock.
Need to verify you have spark. Put a timing light on the coil wire and see if it flashes when cranking.Jeepasaurus (Wagonus Grandi quadropedus)
