FSJ Bushing Sizes
  • HellCreek
    • Jun 11, 2007
    • 179
    FSJ Bushing Sizes
    I have seen several threads here requesting sizes on FSJ bushings, and I thought I would try to help, so here goes: ( I am going to group Wagoneers, Grand Wagoneers and Cherokees together under the heading "SJ" to keep the thread shorter, but I do know that there is a difference - just not in the spring bushings. Also, the sizes are at the bottom of this post.)
    SJs
    1963-73 SJ front springs use a RB-71 (RB-128) anchor bushing and a RB-85 shackle bushing.
    1963-73 SJ rear springs use a RB-87 anchor (post) bushing and a RB-85 shackle bushing.
    1974-75 SJ front springs use a RB-71 anchor bushing and a RB-85 (RB-140) shackle bushing.
    1974-75 SJ rear springs use a RB-141 anchor (post) bushing and a RB-85 shackle bushing.
    1976-91 SJ front springs use a RB-71 (RB-145) anchor bushing and a RB-85 shackle bushing.
    TRUCKS with Rubber Bushings
    1963-73 J-truck front springs with rubber bushings use a RB-86 anchor (post) bushing and a RB-79 shackle bushing.
    1974-87 J-truck front springs with rubber bushings use a RB-71 (RB-145) anchor bushing and a RB-85 (RB-140) shackle bushing.
    1963-69 J-truck rear springs with rubber bushings use a RB-87 anchor (post) bushing and a RB-85 shackle bushing.
    1970-75 J-truck rear springs with rubber bushings use a RB-141 (RB-123) anchor (post) bushing and a RB-85 shackle bushing.
    1976-87 J-truck rear springs with rubber bushings use a RB-153 anchor bushing and a RB-85 shackle bushing.
    TRUCKS with Brass Bushings
    1963-73 J-truck front springs with brass bushings use a LHC bushing on both ends.
    1963-69 J-truck rear springs with brass bushings use either a LHE bushing for the 7/8" post mount or a NJE bushing for the 1" post mount and a LHE shackle bushing.
    1970-73 J-truck rear springs with brass bushings use a NJE bushing on the anchor (post) end and a LHE bushing on the shackle end.
    Bushing Sizes
    RB-71 1-1/2" O.D. 9/16" I.D. 2-1/2" spring width
    RB-79 1-3/4" O.D. 9/16" I.D. 2" spring width
    RB-85 1-1/4" O.D. 9/16" I.D. 2-1/2" spring width
    RB-86 1-1/2" O.D. 7/8" I.D. 2" spring width
    RB-87 1-1/2" O.D. 7/8" I.D. 2-1/2" spring width
    RB-123 use RB-141
    RB-128 use RB-71
    RB-140 use RB-85
    RB-141 1-3/4" O.D. 1" I.D. 2-1/2" spring width
    RB-145 use RB-71
    RB-153 2" O.D. 9/16" I.D. 2-1/2" spring width
    LHC 1-1/8" O.D. 7/8" I.D. 2" spring width
    LHE 1-1/8" O.D. 7/8" I.D. 2-1/2" spring width
    NJE 1-1/4" O.D. 1" I.D. 2-1/2" spring width
    There are probably exceptions to this list (they are, after all, Jeeps), but I hope this helps someone.
    Thanks,
    Tom
  • Stuka
    • Jan 21, 2001
    • 13743
    Would you mind if I put this up in the FSJ Networks FAQ section? I think you may have posted it there once before, I need to look.
    • HellCreek
      • Jun 11, 2007
      • 179
      Hi, Stuka,
      Use it wherever you can with my blessing. What I posted on FSJN was the spring sizes. Kaiserman archived it on this forum.
      Thanks,
      Tom
      • srobertsfsj
        • Aug 26, 2002
        • 1750
        Great Info. Thanks!!
        Scott R.
        '86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
        "After years of being paranoid about my Jeep?s temp going towards that 220F mark, I?m realizing that if it was real problem, Jeep engineers would have painted that area RED." - FSJ Guy
        • fulsizjeep
          • Aug 21, 2002
          • 22496
          Wow, yeah nice contribution! That will help on a couple things going on around here. Thanks!
          • Brandon
            • Oct 15, 2008
            • 3
            adding where to get bushings would be nice, here is the only spot I have found the 2" ones..
            • TPICherokee
              • Jul 02, 2001
              • 3361
              http://napaonline.com/masterpages/NO...ont+Suspension
              What about here:
              1987 Grand Wagoneer - 5.3 Vortec, 4L60E, NP242
              1979 Cherokee Chief​ - 5.3 Vortec, 4L60E, Quadratrac, Alpaca Brown Paint, new stock interior
              1976 J10 Longbox - 258, T18, Dana 20 - Sniper Fuel Injection
              1967 M715 - 454 Chevy, TH400, 1100R16 Michelin XZL Tires, Stock otherwise (sold)
              • JeepinPete
                • Dec 09, 2003
                • 2190
                There is one error in this list. 1976-91 SJ's use three different bushing sizes: RB-71, RB-85, & RB-153, one each at each corner front and rear.
                Pete
                Isuzu 6BD1, NV4500, NP241
