Go Back   International Full Size Jeep Association > Tech Archives > Topic Of The Month
Thread Tools Display Modes
Old 11-26-2002, 02:11 PM
1980chief 1980chief is offline
Post
ok went to replace my shoes in the rear and i can't get the drums off. i don't know thats its not just because they haven't been off in about 10 years or if i have to do something special to remove them...thanks for any help
Darren/1980 jeep cherokee chief
Old 11-26-2002, 03:42 PM
Stuka's Avatar
Stuka Stuka is offline
Post
Get a brake spoon and adjust them out. there is a slot on the back side at the bottom. You need to adjust the star wheel inside. after you back them off then you can get the drum off. This generallly means the drum is very worn out.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 11-27-2002, 05:48 PM
davez26 davez26 is offline
Post
I had a buddy's truck where the adjuster was all screwed up, so I couldn't adjust it out. There were two holes in the outer face of the drum 180 degrees apart. I threaded a couple of bolts in there and turned each one a little at a time until I could get the drum off. Maybe I got lucky, but it worked.
Dave N. --- 1979 Cherokee S NT. 360-Quadrajet/TH400/Quadratrac/D44x2 4.10\'s, ARB front,locrite rear, 35x12.50 BFG Mud-Terrains. Onboard Air,4\"Superlift,2\"body. Warn Winch. Slight body damage. <br />\"Born to Wheel\', Forced to Work.\"
Old 12-01-2002, 05:35 PM
Joe J-Truck Joe J-Truck is offline
Post
One time I adjusted my rear drums all the way off, and they still wouldn't let loose. I tried beating on it with a 5 pound sledge, nope. Finally it took a good hard wallop with a big 20 pound sledgehammer to make the thing let go. Sometimes serious beatings are necessary!
Old 12-02-2002, 09:41 PM
johnwaynejeep johnwaynejeep is offline
Post
Dave,
A lot of time the holes in the front of the drum is made specifically for that, When the drums get stuck just thread some screws in and force the drum off after you've adjysted the brake shoes like Stuka said. I had to do that with my Escort and my Dakota
John Wayne Jeep<br />I\'ll be looking for a 78 J20 here in a few years. My first halftrack project will then commence.
Old 12-03-2002, 01:30 AM
Torque's Avatar
Torque Torque is offline
Post
When your ready to do the brakes go to a place that does free brake inspections.They'll put it up on the hoist removethe drums and giveyou along list of things you must fix.Nodd your head act agreeable and tell 'em you'll have to bring it back at a later date.Drive home andyou'll find the drums snug but quite easy to remove.Also a good time to do a visual inspection of the underside while its on the hoist
Evelynn is an '83 Cherokee Chief W/T with a 360(mildtweek),727,NP229,33x12.5,3.73:1,TFI, MSD6,Painless wiring,CRX seats but the list is growing.
The cynic is one that belives the pessimist is overly optomistic
Thread Tools
